Question about Optics
CAMERA WONT SWITCH ON N12CX - Optics
S45
If the green access light is not working, you should be able to switch of the camera. If the light is out, you can remove the battery and try again. If the camera starts when he battery is replaced, i think the on / off switch is blocked. If the switch is just defect, there is a chance you won't be able to switch the camera on again.
I wish you luck.
Never switch of the camera, when the memory access light burns or flashes.
Jan 14, 2014 | Canon PowerShot Cameras
Won't switch on. Display - switch off camera and turn on again.
This is in a service loop and will not stop until the unit is repaired,
Jan 20, 2013 | FUJIFILM FinePix S2500HD Digital Camera
Camera wont allow me to take photos says
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 13, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
When I press the on/off button, the camera wont work
no the switch is dead - what camera?
Apr 24, 2010 | Cameras
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
It just wont work :(
If it is a rechargeable camera on the camera u will see a small slide switch which says On or OFF or CAMERA MODE OR CHARGER Mode whenever u charge the camera make sure it is in the ON Mode or the Camera Mode
Jul 29, 2008 | Sakar Kidz Cam Digital Camera
My sony dsc h5 camera lens wont open/focus
This might be a problem with the lenses' mechanism... Maybe you hit the camera (having the lenses extended, eventually). You have to pay a visit to the local service.
And in the future, use the protection that came with the camera (the black cilinder). It protects the lenses and also offers you the possibility to mount the lens cap without having to switch off the camera.
Jul 27, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
Camera wont switch on
Try to use another 2 batteries. The problem could be with the batteries or the charger. By the way, did you checked batteries voltage or tried to use them in another appliance ?
Aug 06, 2007 | Sanyo VPC- C6 Digital Camera
Optics Logo
51 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
