Question about Philips MCD708 System
Need new control cable for my mcd708 - Philips MCD708 System
How do I tighten troy built control cable
Its doesn't have an adjustment for the control cable, a new cable will need to be installed
Oct 12, 2014 | Garden
I have a battery operated controller and can not pair it to ps3 please help the controller came with the ps3 as well as standard one thank you
To sync a controller you need to plug it into the usb cable that comes with the playstation itself. If you've lost the cable you will need to buy a new one unless you can find a similar cable.
This allows the controller to be used on multiple playstations, to synchronise a controller to a certain playstation, the usb cable is vital!
Hope this helps.
Aug 14, 2010 | Sony Playstation 3 (PS3) Console
How can I arrange the sound from DVD's to come from the Tv set rather than the MCD708 speakers
Run audio (and video) cables directly from the dvd player to the TV. Don't expect anything but stereo. BTW: this would be a good way to watch TV without the Philips turned on.
The BEST video from anything you watch should go to the TV (with analog audio); and the BEST audio fro manything you listen to should go to the Philips.
Jun 13, 2010 | Philips MCD708 System
Dvd plays in red
try change cable from dvd to tv
Jan 03, 2010 | Philips MCD708 System
All dvds play in red on tv Why?
1st test with another tv.
still the same change the cable conecting from dvd player to tv, and test
if the same, your problem is dvd output internal circuit defective, send dvd player to repair.
Dvd reads 'load' but nothing happens
This issue will occur only when there is a tray with the motor lens problem so you need replace the entire tray with the motor lens set to resolve your issue.
Mar 17, 2009 | Philips MCD708 System
Clock jumping forward 3 hours
Ouch, sounds like it's TIME for a new clock
Mar 12, 2009 | Philips MCD708 System
Philips MCD708 System Logo
255 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
