FixYa.com
Tags:
1989 Geo Tracker
Geo Tracker Vacuum Leak
By LiZzIe - usenet poster
I just pruchased a 95 Tracker with the 16 valve engine. It seems to have
what I would describe as a vacuum leak (It is a pretty loud leak that
you can hear inside the vehicle) that you hear only when lightly using
the addelator. If you are acceleratoring hard it goes away, if you are
ideling you can't hear it only when lightly pushing on the gas. I can't
duplicate it when the vehicle is parked.
The engine seems to run great with the possible exception being the
engine rpm seems to take awhile to go down and then the tach looks like
it does it in stages dropping to about 1500 prm a hesitation then down
to about 1k rpm then down to idle.
I've checked all the vacuum lines on the top of the engine as well as
the connections from the airbox to the intake.
The sound is almost like the sound when there's no air filter on a
carbarated engine.
Anyone have any ides what the problem might be.
Thanks
Wayne Favre
Bothell, WA
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 14, 2008
Not Rated (0)
LiZzIe
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Wayne
It sounds like it could be the same problem that my 89 tracker had.
It was a vacuum leak that was virtually undetectable and certainly not
reproducable when at the dealers shop.
The easy way to find a vacuum leak is to use a blowtorch.
NOT an oxy/acetelene set of torches...a simply propane bottle and screw-on
torch head.
DO NOT USE IT LIT
Now that I have given you the warnings
Start the vehicle, let it idle. Open the hood. Turn on the torch slightly,
do not light the torch, we only need the propane. Direct the stream of
propane at the various hoses around the engine.
When the engine revs, pull the propane away. If the revs go down, repeat to
confirm the increase in revs at that point.
Propane sucked into a vaccum leak will cause the motor to rev. It has worked
for me on several occasions.
Good luck and dont use flamejust the propaneand not too much.
Blair
aka Tonka
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: 1996 Geo Prizm 1992 Geo Tracker 2007 Geo Storm 1989 Geo Prizm 1994 Geo Prizm 1996 Geo Metro 1997 Geo Tracker 2 Door
Can you Help with these Cars problems?
Mitsubishi Montero
v6 pajero engine problem
v6 pajero engine problem Answer This...
Mazda 323
HI!mazda 323 1992. the motor
HI!mazda 323 1992. the motor in... Answer This...
Mitsubishi Montero
pajero v6 starts runs for
pajero v6 starts runs for 2 min... Answer This...
1989 Geo Tracker
89 tracker high idle
Hey guy's I got a 89 tracker... Answer This...
1989 Geo Tracker
fuel pump pressure
I need to know the psi on the... Answer This...
Repair Service
Find Car Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
