Question about Dell Inspiron 1525 Laptop Jet Black
My laptop inspiron 1525 is shutting down suddenly. The battery is not charging. I tried using new battery but still it's not charging. I'm loosing documents and files due to the sudden shutdown of the laptop. Please help me
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 10, 2010
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
Dell inspiron 1525 won't charge the battery
in your case frist chack with any technician let him chack your leptop
or try frist other bettry then only go for a new battery
Apr 21, 2010 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 battery not charging
Take out battery & place it again.
If does not charge again, contact sevice centre.
Apr 16, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
My inspiron 1525 is not charging. Have replaced battery and charging lead and still does not charge.
Based on what you have stated, you replaced the battery and charging lead but the laptop still won't charge. What do you mean by charging lead?
Are you referring to the power adapter?
Since you already changed those two things, then the problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Have a great day!
Oct 05, 2009 | Dell Inspiron 1525 Laptop Jet Black
I am using Inspiron 1525. i am getting the message "Battery can not be identified." and if i will swich of bettary power laptop get shutdown.
I had a battery issue with a brand new Inspiron 1525 today. The battery indicator said that the battery was at 87% the adapter was connected but it was not charging. I had shut down the laptop, remove the battery and adapter, then hold down the power button for 5-10 seconds. Fixed!
if you still get the problem then you will have to replace the battery.
Aug 28, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
The battery has most likely been "Over charged". Most rechargeable batteries can only be charged around 500-1000 times depending on the brand of your computer. I would recommend buying a new one.
May 30, 2009 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 laptop not detecting battery
Looks to me like the battery is bad, try another battery if you can and see if the laptop charges it. If it does then the battery is bad, if it doesn't then its something with the motherboard.
May 21, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Laptop Jet Black  Logo
76 people viewed this question
Alun Cox
