Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
After loading my washer it will not start until the lid is slammed a few times
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description it sounds like you`ll need to replace the lid switch, but first...
Here`s how you can check it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...especially those built in the past 1-2yrs. the model number would distinguish if it applies to your particular model )
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the agitate or spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 10, 2010
Fills with water then won't go to the wash cycle until you slam the lid several times
It sounds like the lid switch is faulty. The washer has a lid switch that checks to see if the lid is open, if lid is open the washer will not start the wash cycle. Check/replace the lid switch and you should be back in business.
Oct 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
WATER RUNS IN TUB, BUT WHEN YOU PUT LID DOWN WON'T START AGITATING UNTIL YOU SLAM THE LID NUMEROUS TIMES
there is a safty switch in the reciever part of the lid assembly it eather is loose or broken ...
Mar 01, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool washer adds water then stops.
Check your water level switch for a blockage in the air hose.
Check the kid switch for good contact.
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Have to slam lid down to get washer to start
Did not want to disect the entire machine to get at the lid switch. Couldn't figure out how to get the corner covers off so I figured we would continue to slam the lid until that no longer worked and then "call the guy". Thanks.
Jul 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
204 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
