Question about Mitutoyo 505 677: Test & Measurement Equipment Measuring Instruments
I have a mitutoyo 500-136 that goes to metric, but won't go back to inch. Last time I had it repaired it cost more than a new one. How do I get it appart, and what can I do to fix it? Thanks
On my brand new calipers I get a flashing dotted line
Sounds like a bad battery contact, and when it looses voltage from the poor contact, it goes back to flashing lines.
Canada's Gauge Specialists
Precision Tool Works - info@precisiontoolworks.com
Dec 18, 2014 | Mitutoyo 500 196 20 Digital Caliper
Tv won't come on
The set is in Shutdown---27 inch may not be worth the cost of repair
Apr 30, 2012 | Samsung TXS2782H TV
How to convert from feet and inches to metric?
Click the screen to access main menu this should bring up the ability to click change preferences and then in that menu you should be able to scroll through and find the option to change from feet and inches to metric.
Mar 02, 2011 | Tomtom GO 750 LIVE GPS Receiver
Readout is flashing a series of dash marks, and will not stop. I just put in a new battery
Hold the origin button for greater than 1 second. You may need to use a point tool to push the button all the way down.
Jan 05, 2011 | Mitutoyo 500-672 0-6" ABSOLUTE Digimatic...
Need to know the tolerance on the Model 547-500 Brand Mitutoyo
http://www.mitutoyo.com/TerminalMerchandisingGroup.aspx?group=1247
+/- .001 inch
Feb 10, 2010 | Measuring Tools & Sensors
WHILE I WAS WORKING MY MONITOR SUDDENLY TURNS OFF PERMANENTLY BY GIVING A SPARKING SOUND INSIDE MONITOR.THE LOCAL REPAIRMEN ARE SAYING ITS EST AND IC IC GONE.HOW LONG IT WILL RUN IF I REPAIR IT?OR I SHOULD...
Most repairs only carry a 30-day warranty. After that the monitor is subject to going out at any time. Then again, if the repair is done correctly, it could last for years. Check the cost of repair against the cost of a replacement monitor. Prices have come down drastically in the last 2-3 years, and you can pick up some real bargains. I just purchased an as-new 21-inch LCD for for $86 on eBay.
Dec 16, 2009 | Cars & Trucks
Fluke 8060AA digital multimeter
The fuse has nothing to do with the display.
The contacts of the LCD are probably oxidized because of its age. With the unit out of its care, carefully remove the LCD from its retaining mount. Use rubbing alcohol and a clean q-tip to clean the contacts of the LCD and the small "rubber-like" strips that contact both sides of the LCD. Also, remove the strips and clean the other side and the contact on the main circuit board. Then reassemble.
*Note, if you live in a cold climate, freezing of the LCD could also cause this problem. In that case you must purchase a replacement LCD from Fluke.
Oct 10, 2008 | Mitutoyo 0-18"mitutoyo Electrnc Digi-matic...
Mitutoyo 505 677: Test & Measurement Equipment Measuring Instruments Logo
93 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Doug Adams
Doug Adams
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
