Hi, i have a lg rear projection tv model no. 62dc1d-ab and i was wondering where i can buy a new lamp bulb for it, lamp number p22-hd5, lamp model as-lx60, 31419sn984a. And i also need directions in changing it some-one said not that hard....
Make sure your TV is turned off at the power switch for at least half an hour. Undo the two screws on the lamp cover which is on the right hand side of the TV as you look at the screen.
Remove retaining screws on lamp case.Lift up fixed wire handle on lamp. Pull out knob slowly and remove lamp case. Insert new lamp gently. Tighten screws. Replace cover.Reset lamp time on menue.
Posted on Sep 18, 2010
Testimonial: "Thanks for that worked a treat perfect picture only now i have a humming noise in the back that does not go away???"
LG projection screen television model 62DC1D-AB switches on then keep switching off and the symbol looks like a flashing light globe what does this mean
Your LG HDTV is in protect mode that why you can see light .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted or leak capacitor in power supply section.
Regards:
votit
Feb 03, 2011 | LG DU-62SY20D 62" Rear Projection HDTV
The tv turn on and turn off by it self
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | LG RU-52SZ61 52 in. Rear Projection...
I have a 60 inch LG t.v. that needs a new bulb
The part number for the lamp is: 6912V00006C
It can be purchased from tritronicsinc.com for $199.00 plus shipping.
Dan
Dec 17, 2009 | LG RU-60SZ30 60" Rear Projection...
My lamp light is on and the tv says that I need to change the lamp (to get a better picture) I believe the part number is 31419SN984A . Can you tell me where can I buy a new lamp and is it diffcult to...
Encompass.com has the lamp you need for $248.94, the part number you gave 31419sn984a is correct. It is a bulb only you have to remove the lamp door then unscrew the lamp and pull it out of the set, then you must dismantle the housing and replace the bulb then put it back in the set and replace the door.
Oct 30, 2009 | Zenith Z62DC1D Television
Lg 62dc1d-ab rear projection tv. the picture has gone very darl even at full brightness
ure bulb will be on the way out go into the menu and there should be a lamp counter if its close to 8000 hours then its due for one, check ebay for cheapest price as they arnt under warranty
Sep 23, 2009 | LG Televison & Video
Z62DC1D DLP TV
There is a substitute bulb for your TV. Part Number 6912B22010A available at RT Edwards Ipswich for $ 198
May 31, 2009 | Zenith Z62DC1D Television
RT 52SZ30
I have a 52" LG Prjection TV model number RU52SZ30 and it turns off after 45 seconds, also the blinking lights flickers on the lamp. What should I do first replace the lamp or reset the tv and how can I reset my TV. If a lamp problem where can I purchase one and how much and if I buy a lamp and I still have the same problem what do I do now.
Thanks.
Sep 03, 2008 | LG RU-52SZ30 52" Rear Projection...
52hmx85 toshiba
yes it is, here is the advice on bulbs:
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. Really easy.
Hope ya fix it!
Jan 04, 2008 | Toshiba 52HMX84 52" Rear Projection...
Hitachi Rear Projection LCD TV Lamp
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Oct 17, 2007 | Hitachi 50V720 Television
Televison & Video Logo
456 people viewed this question
Top Televison & Video Experts
Electro Med Services...
