Question about AOC 718Swag-1 LCD Monitor
AOC 718swag-1 displays "Out of Range" - AOC 718Swag-1 LCD Monitor
  • 11,361 Answers
How do I reduce the brightness of my AOC monitor?
If you are using windows XP :
1.Right click on desktop
2.Properties
3.Settings
4.Advanced
Windows 7:
1.Open Display Color Calibration by clicking the Start button , and then clicking Control Panel. In the search box, type calibrate display, and then click Calibrate display color. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
2.In Display Color Calibration, click Next to continue
Aug 01, 2011 | AOC Monitor
Screen+ application that came with my AOC monitor isnt working when I try to change the configuration to multiple on display 1 or display 2. What happens is "AOC grid screen executable file has...
This sounds like a computer problem and not really a television problem. Check your driver files.
Try removing your driver files. Then disconnect your AOC monitor. Reboot the computer and login. Shut down the computer and reconnect the AOC monitor. Start the computer. Now install the monitor drivers.
Jun 27, 2011 | AOC 23 E2343fk 23 LCD TV
Windows 7 screen goes to large resolution and needs reset on startup.
Turn on the PC. Press F8 at booting into windows 7. It will display  many options
Select the Enable low resolution video(640x480) then login to system.
then change the resolution as required
Right click on a empty space on the desktop and click on Screen Resolution.
Enable low resolution video (640 × 480)
Jun 08, 2011 | AOC 718Swag-1 LCD Monitor
I need driver display AOC 912Sws-1
Hi artopa,
You can find the drivers here:
http://diplo-driver.com/download-driver/AOC/912SWS-1
If this helps resolve your issue, would you please rate the solution. If this does not help please leave a comment giving me more information on the problem and I will try to help you further.
Dec 29, 2010 | AOC International AOC Monitor Driver
AOC 212Va-1 problems with DVI
no you just install an AGP card into the AGP slot of the motherboard then you can see any high resolution because your motherboard is with inbuilt display card will not support to high resolution external card is necessary for that
Mar 12, 2010 | AOC 212VA-1 Monitor
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
Speakers or not
If your monitor has speakers built in, it's likely that there is an Audio Out port on the back or one of the sides. You can use a simple 1/8" input/output cable that will connect to the port on your monitor and the Audio In port on your desktop.
If you already have that set up correctly and you are still not hearing any audio coming from the monitor, there may be a configuration console that is available after installing the software for the monitor. If you don't see any software installed, find the installation disc and see if there is an application available to install.
If you don't have the disc, you might be able to find the software online at the manufacturer's support site.
You might also be able to change some configuration settings from within the Sounds and Audio Devices console in Control Panel.
Hope this helps! Good luck!
Aug 09, 2009 | AOC 718Swag-1 LCD Monitor
Hi...my AOC 17" CRT monitor display on the screen says NOT SUPPORTED OUT OF RANGE... i try to change the screen resolution by using other monitor but still nothings happen..
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Dec 12, 2008 | AOC CT720G 17" CRT Monitor
"Not support Out of range"
You have to boot your PC in safe mode using press F8 key.
after that you decrease the resolution in the display setting section.
It will help you.
Nov 29, 2008 | AOC CT720G 17" CRT Monitor
AOC 718Swag-1  LCD Monitor Logo
380 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
