Question about Neovo A-17 (Black) Monitor
Screen menu e.g brightness and screen size, is on and no way of getting it off
  • 732 Answers
Regencyfirep, First, this unit is listed on Retrevo . com as "over the hill, and should be retired. What is "date of manufacture" from rear of monitor? Symptom indicates possible "switch-mode-power-supply" +5.00volt may have "noise" or be a bit out of "regulation" and that will cause the VGA to lcd processor/converter board to "act stupid" and not recognize valid front panel "menu key presses" !!! Does this unit have lay on floor "black-brick" power supply or just a line cord to wall outlet? Unit may need $6 in new electrolytic filter capacitors installed on the SMPS board. If unit is "mission critical" , then sub-in working unit till you can investigate power supply board for swollen,leaky filter capacitors unit may have. If you have solder, solder-wick, soldering pencil(40watt) visit YOUTUBE for "lcd monitor disassembly", "lcd monitor repair" video clips that show typical repairs. Let me know brand name (CapXon, Elite, Jun-Fu) of capacitors used on SMPS board. Read fixya profiles of "budmrtn" "buddymc" "12fixlouie" and testimonials for more info on DIY repair. Hope this response helpful to you. 12fixlouie
Posted on Sep 10, 2010
On a kindle fire 7 can you increase the font size of a downloaded book?
Hi. Yes this is possible. With the page in view double tap on the screen. A menu appears at the top of the screen. Look for the icon Aa. On opening this there is a choice of options e.g. Brightness, text size, colour, font etc. To change the text size tap on the + sign and the text size will increase. To decrease use the - sign. Enjoy your kindle.
Jan 05, 2018 | Tablets & eReaders
Seiki 24" has audio but the display was complettly white bright
Hi, this is a failed IC on the board which overheats. Sometime if you leave the TV for a couple of days if might work after.. BUT it will eventually go white again. If under warranty or extended warranty then you can get it repaired.
Simple test is you get no Menu on the screen even though you press the remote Menu Button
Considering its size (24") I would not recommend a self-repair due to the cost involved.
Sep 27, 2016 | Seiki 24" Class 1080p 60Hz LED HDTV...
My Sharp 70 Aqous LC-70LE65OU has bright green vertical line all thru it with what appears to be instructions, ie enter, menu in the background.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size
Apr 12, 2016 | Sharp Televison & Video
How do I get full screen on my samsung 45?
Those settings do not alter screen size, only the contrast/brightness. You need to go to the menu that alters 4:3, letterbox etc.
Sep 15, 2014 | Samsung Samasung 32inch UA-32EH5300 Smart...
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Got moniter working but screen is too wide for monitor i have to usw cross arrows to read the whole page
Each monitor has settings buttons on the front or side of the monitor to set the screen size, brightness, etc. Look for a button or wheel and find the menu, then go find the screen sizing, but verticle and horizontal and move it so it fits the monitor screen.
Pushing buttons on the monitor will not cause any damage, so try then all until you find the menu button and then you will need to find the button or wheel that moves you from selection to selection. Generally, pushing the menu button will select the highlighted menu item so you can adjust the settings.
I hope this was helpful.
Brian
Dec 24, 2010 | Computers & Internet
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
Kogi 17'' flat screen monitor
there are four(4) buttons on your monitor to the left of the on/off switch.
Press the first one to the left of the off switch, which will bring up a menu, so you can select
bright or volume, screen size, etc; Next, there are two (2) buttons to the left of the first left button
that you can push to adjust brightness, size, vertical, etc;
Apr 03, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Samsung i5 camera
Try the following and see if this helps:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Aug 12, 2008 | Samsung Digimax i5 Digital Camera
Dell m782 Brightness control???
Brightness is adjusted by using the 2 buttons on the left side of the front.
See instructions here:
http://support.dell.com/support/edocs/monitors/m782/En/controls.htm
Jan 04, 2008 | Dell M782 Monitor
Neovo A-17 (Black) Monitor Logo
44 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
