Question about Kitchen Ranges
What oil and petrol mix i use.on generator ryobi rg2700
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
robotek
  • 1512 Answers
SOURCE: oil
Hi KK
Use 600 ml is you are changing the oil, or 650ml  if you have just rebuilt the engine and filling from dry. Use light weight gear oil.
regards robotek
Posted on Dec 20, 2008
pippall
  • 1486 Answers
SOURCE: petrol oil ratio mix
25%to!%
Posted on Aug 09, 2009
farmerbear
  • 490 Answers
SOURCE: i have a petrol black
50:1
Farmerbear
Posted on Sep 11, 2010
Testimonial: "Thanks for the info. I've been trying to get the right mix for ages."
  • 252 Answers
SOURCE: What is the 2 stroke
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Posted on Jun 03, 2011
Testimonial: "pauly46 - many thanks for your prompt reply! Much appreciated!!"
I have a Ryobi RPT3000 trimmer. Firstly how do I top up engine oil? And then how do I restring it?
The engine on that trimmer will be a 2 stroke 30cc engine not a 4 stroke.
"Two Stroke Oil" is added to the fuel for a 2 stroke fuel mix in accordance with the proportions specified by Ryobi for that engine. The required petrol/oil mix may be printed on the top of the fuel cap. No other oil is used in a 2 stroke engine.
There are a number of videos on Youtube people have uploaded which will show you how to replace the pull cord on a trimmer.
Dec 28, 2015 | Ryobi Garden
Tip
Ryobi starting problems
If youtr ryobi petrol/oil mix machine will not start then check these out first.
1 . No spark change the plug but dont forget to check the plug gap.
2 . Still no spark change the HT lead
3 . Clean fuel/mix
4 . Lastly check the on/off switch for ware or rust and clean if ness
on Jul 29, 2010 | Garden
Bought it at local, start alright with petrol. When try with 2 Stroke RYOBI Synthetic Oil hard to start. Should i just use normal petrol oil?
no --- 2 strokes use a special 2 stroke oil ==not ordinary engine oil==
the difference is that the 2 stroke oil is specially blended to mix with petrol and will not block up the fine jets in the carby
it also "sticks " more readily to the metal components in the engine thus preventing wear
as a point of interest most small engines do not like E mix fuels either
so for trouble free operation --2 stroke oil mixed in the correct ratio with either 89 or 91 octane petrol and it will start first pull every time
use the primer bulb sparingly or the choke until it fores
Oct 19, 2015 | Homelite Garden
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
cheers pauly46
Jun 02, 2011 | Garden
I've lost the user manual for my Ryobi 25cc RPT 2543c strimmer. Can you please advise where the dip stick is to check the oil. Can't seem to find it.
Ryobi RPT 2543c This is a 2 stroke engine, so no dipstick. You mix oil with the petrol (ratio 50:1) or 200ml of two stroke oil per litre of petrol, and that's how the engine is lubricated. Hope this helps, arvidis@btopenworld.com
Apr 19, 2011 | Ryobi Garden
Hi Please can you confirm what fuel the Ryobi rg6700k generator takes?
Hi. I've been looking online and there's no information about this model. However this is how to tell which fuel it uses. If it has a spark-plug it burns petrol. Diesel engines don't have spark-plugs they use glow plugs which are different. Spark-plugs have a spark gap which the spark jumps across while glow plugs do not.
If it has a separate place for putting oil, and a dipstick for checking the oil level, then the fuel is petrol only. If it doesn't have a place for oil then the fuel is petrol mixed with 2 stroke oil. I hope this answers your question.
Jan 19, 2011 | Garden
Ryobi 30cc trimmer won't run. Difficult to start, hard to keep ru
chnge the plug for the best you can get then depending on the mix petrol oil mix u could cahnge that ie if its 50:1 go down to 40:1 or visa versa if that doesnt work bin it and get a sthil or an ehco
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi PSC 3046y3e 30 cc petrol strimmer ratios of petrol to oil
WELL IF THERE IS NO 2 STROKE OIL TANK THEN YOU MIX IT WITH THE GAS. THIS IS HOW THE ENGINE GETRS ITS LUBRICATION AND WILL BLOW UP AND SEIAZE WITHOUT IT.MOST OF THESE SMALL ENGINS RUN AR 20 TO 1. OUTBAURDS RUN AT 50 TO 1. IF YOU PUT TO LITTLE ITS NO GOOD AS MENTIONED ABOVE. IF YOU [PUT TOO MUCH IT IS NT AS BAD AS IT WILL SMOKE A BIT AND POSSIBLE FOUL THE PLUG AFTER A WHILE. I WOULD GO WITH 230 TO ONE THAT WOULD BE 20 PARTS GAS TO 1 PART OIL 20GAL GAS TO 1 GAL OIL IS THE SAME AS 5 GAL OF GAS TO 1 QUART OIL OR 2 1/2 GAL GAS TO A PINT OIL OR 1 1/4 GAL GAS TO 1/2 PINT OILM GET THE PICTURE NOW. ITS DIVISION. AFTER A WHILE OF RUNNING IF IT SMKES AND THE PLUG FOULS JUST ADD A BIT MORE GAS TO YOUR MIX AND CLEAN THE PLUS WITH AN OLD TOOTH BRUSH AND I ALWAYS MARK MY GAS CAN WITH BLACK MARKER OIL/GAS MIX 20:1 OR WHATEVER.
REGARDS, PAUL
Jun 20, 2009 | Ryobi Cultivator
Kitchen Ranges Logo
260 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
