Question about Abit Fatal1ty FP-IN9 SLI Motherboard
I dont seem to be able to enable sli memory on my ABIT Fatality FP-IN9 SLI . Im using: q6600 cpu, crucial ballistix 800mhz ram (4 x1gb), 8800gtx x 2 graphics(in sli mode) The bios says sli memory detected but whenever i enable sli memory in the bios and try to reboot, the screen dosent come on and i have to ccmos.
map9966
  • 2351 Answers
SOURCE: Memory problem.
Check your manual pg. 2-12. Qualified Vendors List. The QVL is tested memory for your board. There was a small fix to memory with bios version 1015. Go to Asus web site for information regarding this update & others. http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Feb 01, 2008
  • 18 Answers
SOURCE: i need a picture to follow.. help
This link will download the manual from the Abit website. It should have the parts fairly well labeled. Good luck.
Posted on Feb 21, 2008
  • 11 Answers
SOURCE: Blank screen at boot up
Sounds like you need a new motherboard how old is his computer but, before you start looking for a new board try resetting the main board jumpers maybe that will get it to work and if there are no jumpers remove the battery from the motherboard this does the same thing.
Posted on Jun 02, 2008
frankgant
  • 250 Answers
SOURCE: Well my system temperature is
Many motherboards take two temps. Motherboard temp and CPU temp. CPU temp is the most common problem. Check there first. You might need a faster fan or a larger heat sink. Also make sure the pc isn't enclosed in anything. It needs to have air moving around it on both main sides, the front and back.
Posted on Dec 17, 2008
TULOA
  • 57 Answers
SOURCE: System temperature too hot
Its measured in Celsius. Meaning alot higher in Fahrenheit. That would be the Processor.
You are looking for something that will be Square or on a Card that is in the motherboard.
Why doesn't it do POST?
Put a hard drive with an operating system on it.
Jan 01, 2016 | Abit Fatal1ty FP-IN9 SLI Motherboard
I have a Fatal1ty FP-IN9 SLI motherboard installed in the case with a 750 watt power supply. I turn on the power, and it runs the Plextor CD writer with an XP installation CD and does not boot the hard...
If there is a disk in the cd device the bios is set up to boot up from there first. So if you have a xp OS disk in there that is what will happen . Remove the disk and it should boot from the hard drive if it is properly loaded.
Sep 09, 2017 | Abit Fatality aa8xe (MBFAA8XE) Motherboard
After testing the memory,gfx card a different hd my PC still turns off at some point once it hits the desktop,took the battery out but nothing seems to stop it shutting down.
The CPU and cooler are they installed properly? Is the Power connector pluged in correctly, both the 20pin + 4 pin and 4pin for CPU? The Black cooler over whats called the north bridge is it extremely hot? Need to keep it cool!
damnor01
Nov 27, 2010 | Abit Fatal1ty FP-IN9 SLI Motherboard
Abit Fatal1y FP-IN9 Boot Problem!?
check your jumper settings. You can probably view jumper diagram online. Make sure all drivers are downloaded and up to date. Try placing windows installation disc in before booting pc. Also check boot setting to make sure hardrive boots second and cd boots first. Also make sure your hard drive jumper is set to master.
Jul 02, 2009 | Computers & Internet
Installed a new processor and now it wont work
Is that an upgraded processor? If it is, then somehow, it could be its configuration problem with the older processor on software side. Your previous installation of OS remember its past processor and reporting error.
You can try fresh installation. Just for the input.
Apr 04, 2009 | Abit Fatal1ty FP-IN9 SLI Motherboard
Running dual bfg 8800gtx oc2
Hey, I own the same board, well the brother model, M2N-SLI and on both boards its the same, X8 when two cards are used, 16 when only one card is used, I have 8600GT two of them, previously used in sli, but now with 3 monitors I don't use sli at all, I still think both cards are working at x8 even if sli isn't enabled.
Sep 24, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Jun 02, 2008 | Abit Fatal1ty FP-IN9 SLI Motherboard
I need a picture to follow.. help
Feb 21, 2008 | Abit Fatal1ty FP-IN9 SLI Motherboard
Memory problem.
Feb 01, 2008 | ASUS A8N-SLI Deluxe Motherboard
Abit Fatal1ty FP-IN9 SLI Motherboard Logo
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
