Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Wild Thing 18" chainsaw model 952-051338 Spark
Wild Thing 18" chainsaw model 952-051338 Spark plug size/type? Fuel mix ratio? Where can I get an operators manual?
  • 3 Answers
Spark plug size= 3/4 or 19mm. Champion RCJ--7Y gapped to 0.025.
Fuel mix= synthentic 40:1.
http://www.manualsonline.com/ex/thread/view/idThread/3524133
Posted on Oct 24, 2010
My 2006 poulan wild thing chain saw 42cc will not hit at all i am getting fuel
check for spark, if you have spark pour a very small amount of fuel down the spark plug hole, if it runs for a few seconds and stops. You have a fuel problem. If there is no spark, try a new plug, if still no spark you have an electrical problem. All is assuming you have compression. If no compression your motor needs refurbishing.
Oct 23, 2016 | Poulan 18" Wild Thing Chainsaw
I have a poulan wild thing,and i can:t get it to start,any suggestions.thank you robert hollenbeck emai,jiggsh@yahoo.com
Things to check, drain the fuel tank and re fill with fresh fuel oil mix, remove the fuel filter from the fuel tank and replace, check the condition of the fuel hose up to the carb, if cracked then replace, remove the spark plug, rest it on top of the cylinder ( away from the plug hole ) crank the engine and look for a spark, if that is ok, remove the muffler and check the condition of the piston through the exhaust port, any signs of scuffing and it will need to come apart to assess the damage.
Jun 21, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan 18in 40 cc WildThing ChainSaw Won't Start.
Start with basic tests, drain the fuel tank and fill with fresh fuel oil mix, remove and reolace the fuel filter on the edn of the fuel hose, check the fuel hose up to the carb for leaks, remove the spark plug, rest it on the side of the cylinder ( away from the plug hole ) cramk the engine and check if you have a spark.
Apr 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is gas oil ratio for a 16 inch poulan chain saw
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Won't start and when it does it will start hot but cold it takes forever to get it started if at all.
try and make sure your fuel oil mix is to the manufacturers spec. take out your spark plug give it a good clean, before running again drain all old fuel and replace with the correct consistancy mix. this should fixya prob mate
Apr 16, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Gets hot, sizes up.
Clean carb. Pull apart and soak in carb cleaner. Blow dry with air nozzle. Make sure air filter is clean and plenty of air. Make sure spark plug is not gapped wrong and running to hot. Make sure oil/fuel mixture is accurate
Nov 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
1,878 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
