Question about Dirt Devil Reaction Twin Cyclone Upright Vacuum
How to replace handle release pedal on dirt devil kinetix self propelled vacuum cleaner. I need to remove the broken pedal and replace it with the new one.
galati2k
  • 281 Answers
SOURCE: Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Posted on Apr 08, 2009
galati2k
  • 281 Answers
SOURCE: The Dirt Devil 085850 doesn't pick up anything!
the intake hose is clogged thats the clear looking hose that comes up from the bottom on the back side.you will need a coat hanger wither the end bent so its rounded.on the back where you sere the clear hose it conects to a fitting that is held in by one or 2 screws take them out and work the coat hanger down through the intake hose.you should be able to push the clog out through the bottom
Posted on Apr 09, 2009
woobie dog
  • 1273 Answers
SOURCE: HOW DO YOU CHANGE THE BELT ON A DIRT DEVIL VISION
With the vacuum unplugged, turn the machine beater bar side up. Locate the clips or screws that hold the plate over the beater bar and remove the plate. The beater bar sits in sockets just inside. Be careful in removing it; take your time and note how it comes out...this will make reassembly easier. Clean the debris while you have tha bar off and remove any debris thet you see in the vacuum hose area behind the bar....The new belt slips over the motor shaft behind the beater bar (further up in the cavity behind the b/b), then you slip it back onto the beater bar as you place the bar back nto the sockets. Test your work by revolving the bar a bit to make sure that everything is back in place. Replace the plate.
Regards,
--W/D--
Posted on Jul 12, 2009
nwj2468
  • 76 Answers
check to see if it's clogged anywhere.
Posted on Aug 22, 2009
goodgold
  • 389 Answers
SOURCE: belt installation
The Regard. I performed this not once, and every time on move разберался. Nothing complex in general no. Simply take off first all lids, will afterwards find the bolts and staples, which keeps the rack vacuum прижима, will be an кольца and pucks. This simply. I shall prompt here is in than, sting you do not indicate the models so I have sent you manual , was more simply. There is some tricks. 1. You will be necessary to remove whole frame don't care, without this their will not draw on frame, her(its) it is necessary to remove. 2. Can be the belt only sprawl and so they slip. But condition belt good, simply they were extended and become more. So here is, remove the belt, set in order frame wipe the belt by liquid for rubber to moisten the belt. And when belt ready do so. Reel sticky summer скотч or another on grosses on which belt move, there there is drive axises and simply passive axis, so reel on drive if you will wind 2 mms, that this will it is enough, belt is drawn. Install the belt all and swab the axis a mask. Check that they all synchronous revolve and collect in inverse order frame. The Economy more $120US...
Thank you, good luck, write, I Sergey
Posted on Sep 14, 2009
Why won't hoover wind tunnel self-propel?
Hi there! The self-propelled feature is controlled by a belt. Check the belts on your Hoover Windtunnel by following these quick steps.
1. Recline the handle. Lay the cleaner fat and flip it over to expose nozzle base.
2. Remove the screws attaching the nozzle.
3. Check that the belts are not broken, stretched or damaged.
Replace the belts if they are damaged. Hope this helps!
Jul 04, 2014 | Hoover Vacuums
Why will my Dirt devil easy steamer not releasing cleaning solustion
Hi! You may need to prime the trigger to get the solution flowing. To prime the trigger recline the handle and pump the trigger vigorously about 30 times. Power the cleaner on and hold the trigger in for 30 seconds. Be sure you are only using the Dirt Devil cleaning products intended for use with this machine. Using something other than the specified detergent can clog the lines that deliver the solution. If your cleaner still isn't dispensing you can take it in to a Dirt Devil authorized service center for repair. I have included a link where you may go to locate a service center near you. Hope this was helpful!
May 22, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
Can't lower handle on Hoover wind tunnel vac U6432-900
Anne, Do you mean that when you depress the pedal on the left side of the machine body that you can't get the upper portion to release into a lower mode? Or are you fully depressing the pedal?? As for the switch for the self propelled mode, that's actually just a small button that you move around in the slot of the handle to select which mode you want to use. It's not actually a switch. If you are fully depressing the handle release pedal and it's not releasing, you should take it to the store where you purchased it, if it was a vacuum store. If you bought it at a big box store, then you'll need to take it to some repair shop that does warranty work, if it's within the warranty period of course.
Nov 10, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
The vacuum is not rolling easily. It "drags" on the rug.
Hi There,
When a Hoover Windtunnel becomes hard to push, this usually indicates that self-propelled has stopped working.
When this stops working, it can be caused by several things. The first, most common problem is that the belts have either broken, or stretched to a point where they no longer engage the self-propelled mechanism. In order to verify this, simply make sure that the machine is set to the Carpet setting, turn the machine on, and turn it over on it's side with the handle release pedal reclined (make sure it's not in the upright position). Is the brush at the bottom of the vacuum spinning? If no, this definitely indicates that your belts have gone bad and need to be replaced. There are two belts on your machine, one controls the brush, the other controls the self-propelled mechanism. We've shot a helpful video that walks you through step by step on how to replace the belts.
This is by far the most common problem that we see on your particular model:
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
May 06, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Self propelled feature does not work. I replaced
There is a cable from the handle down to the transmission on this machine that breaks all the time or the cable is mounted to a plastic piece that is broken. That will need to be replaced.
Nov 28, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
I have a dirt devil vacuum made by Royal. It is a
You need to change the belt. If it is self propelled it will have two belts. You can find the type of belt you need in the manual and then you can get the belts here:
Dirt Devil Replacement Belts
Nov 06, 2009 | Vacuums
Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Oct 01, 2007 | Vacuums
My dirt devil featherlite vacuum cleaner
that vacuum is self adjusting it will do it by itself
Jun 11, 2007 | Dirt Devil M085570 Bagged Upright Vacuum
Dirt Devil Reaction Twin Cyclone Upright Vacuum Logo
47 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
