Question about Whirlpool CAM2752RQ Coin Operated Commercial Washer
I have a whirlpool washer that only fills up half way in the rinse cycle, is this normal
    Problem Solver:
I have a similar machine and was wondering the same thing.... can this be set to fill up fully on the rinse???
Posted on Jun 11, 2011
  • Cynthia Younger
    Cynthia Younger Jun 22, 2014
    I have a coin washer and its overflowing and flooding my wash room. Is this a problem with these type washers?
My whirlpool washer periodically gets stuck on rinse.. the water continues to run but its only about half full so it must be draining. My water bill was over $100 last month, please help.
check the lid switch, if it isn't working right the machine will not enter the spin cycle, also the timer may be going bad, it could stay stuck in between the rinse fill and rinse cycle
Jun 21, 2011 | Whirlpool Washing Machines
Whirlpool auto load not filling with water to wash, but will go to rinse cycle
There are 2 inlet valves 1 for hot water and 1 for cold. Sounds like your hot water valve is either faulty or the hot water valve to it is off. The machine normally fills with hot water as it doesn't have a heating element to heat the water and fills with the cold water to rinse
Feb 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Jan 19, 2010 | Kenmore Washing Machines
My whirlpool washer fills up with hot / warm water (cold doesn't work) pretty quick for the washing cycle but it takes forever when filling the rinse cycle....help
The amount of water on the rinse is lower becaus it's using cooler water. You stated that the cold water isn't working.
Shut the water supplies off. Take the hoses loose from the hose bibs. There should be screen washers in the end of the hose. These are to catch the sediment that normally flows through the water supply pipes in our homes... Take the washer screens out and clean them with an old toothbrush.
Reinstall and while you're at it clean the hot side too.
Then take the machine end of the hoses off and check that it's all clear there as well.
Re install and run your machine on a cycle and monitor it to see if there is better flow on the cold wash cycle AND the rinse portions of your cycles...
If there is no screen washers in the hose, chances are you'll need to clean the water supply valves in the machine... real fun.. HOPE There's washers in your machine..
K
Jul 24, 2009 | Whirlpool Washing Machines
Whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Apr 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Whirlpool washer: Very slow fill cycle on the
I had a similar problem - unscrew the water hose feed lines from the back of the machine and clear out any sedimentation build up from the filters. You can use a turkey baster to siphon off. If filters are clear you may have to replace watervalve. Look at vitual repairman,com as to how to remove the back. Replacement cost about $26.
Mar 27, 2009 | Washing Machines
Washing Machines Logo
434 people viewed this question
Dan Webster
Dan Webster
Sal De
