Question about Briggs & Stratton Garden
I have a flymo rotorvator 5 hp briggs and straton engine it runs for about 5 minutes and then stops if i leave it for 10 mins or so it starts again any solutions please
    President:
  • 2,468 Answers
Replace the electronic ignition module
Posted on Sep 10, 2010
22 hp Briggs and Straton
see if your loosing spark when this happens if so remove the upper engine cover and check for debris build up over heating the coil and engine
Jun 25, 2012 | Garden
I have a 22 HP briggs engine. Runs great for 15 to 30 minutes and then loses power. Let it sit for 10 mins. and good again for short time. It has a fuel solenute and it works but gets very hot. I mean very...
Are you saying the engine gets hot or the solenoid..if engine ? What oil are you using should be no lighter then SAE 30 for summer vehicles..Sounds more like your oil is breaking down and your Pistons and rings are getting tighter..the motor will start to work hard getting hotter from friction..if solenoid it should be replaced..Hope this helps..good luck
Apr 29, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs straton 6.75 starts to die..if i open the fuel cap it runs again. also wont start when hot. twenty minutes or so it's fine again.
hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a clogged vent, this is a small thing but a big problem,,hope this helps, ``
Feb 20, 2012 | Troy Garden
I Have a Masport 635 Mower with a 3.5 HP Briggs & Stratton Engine (3600 R/Min (SAE J607)) that continullay stops. It starts fine and then after about 2 minutes it just stops. It only restarts if...
check the valve clearance on the hot engine
chances are that there will be none as B7S engines tend to stretch the valve stems and close off the gap-
Feb 10, 2018 | Garden
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Feb 05, 2010 | Craftsman Garden
Lawnmower with 5 hp briggs ad straton engine.starts fine when cold and runs well but if you shut it off ,it won't restart when its hot
It sounds like the choke is comming on or you are prinming it again? Dont prime a warm engine
Nov 16, 2009 | Garden
Garden Logo
301 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
