Question about Motorola Audio Players & Recorders
We have a mag one BPR40 walkie talkie and the clip to hold the battery in is broken, we would like to replace it. How can we do this ourself? We have a new clip to replace the broken one.
xMadx
  • 64 Answers
SOURCE: walky talky
A walkie talky as we called them, back when we were younger - and hell we probably still do in some respects, hence the fact my friend still refers to her cordless phone as a "walkie talky" and the principals haven't changed that much.
The common old Walkie Talky or CB radio use what we call a half duplex, that means only one person can talk at a time. We are talking and listening on the same channel.
Cell phones are full duplex, meaning two way conversation, and this is simply listening on one channel whilst talking on another, so the basic principal is basically the same, just a little more sophisticated.
Walkie-talkie typically has one channel
CB radio has 40 channels.
Cell phone
can communicate on 1,664 channels or more!
I have included a link to a circuit diagram.
http://www.freeinfosociety.com/electronics/schemview.php?id=1870
There is also two links below, building the transmitter & receiver.
Transmitter: http://www.zen22142.zen.co.uk/Circuits/rf/2bjttx.htm
Receiver: http://www.electronics-tutorials.com/receivers/regen-radio-receiver.htm
Trust this helps, and please take the time to rate the answer given, thank you.
Posted on Feb 04, 2008
SOURCE: Columbia Walkie Talkies - Model: GM3W - need batteries
I have the same radios, working, with a charging dock - no power cord though. I was just going to try and sell the set. usmc_nevarez@yahoo.com
Posted on Dec 22, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
SOURCE: charging walkie talkies
This is more for "mshtexas" than the OP but I'm sure there may be others out there wondering the same thing. The power cord that comes with this unit has a 9.0v output at 200mA with the center pin being positive
Posted on Jul 01, 2009
  • 11800 Answers
SOURCE: My children have found a
The button on the left, front case, starts it. The 2 buttons on the right, front case, selects the channel. The other 2 buttons selects the mode - make sure that both are on the same channel and same mode. To speak just press the big button on the side.
If the unit doesn't starts then it's defective - the reason it was thrown away.
Posted on Sep 03, 2010
Mag One BPR40 not powering
Contact Motorola Solutions (http://www.motorolasolutions/support)
Jun 26, 2014 | Motorola Mag One BPR40 Two Way Radio
What is the range of the uniden black walkie talkie gmrs 520
  • Pair of GMRS/FRS 2-way radios for person-to-person communication while hiking, skiing, and more
  • 22 channels (8 GMRS and 14 FRS); wireless range of up to 2 miles
  • Auto squelch function shuts off weak transmissions and unwanted noise at range limit
  • Single call alert tone; automatic power save circuit extends battery life; includes 2 belt clips
  • Each radio runs for up to 48 hours on 3 AAA batteries (not included); 1-year warranty
May 30, 2014 | Uniden Black Walkie Talkie Gmrs 520
Removal battery clip
This can be a trick. You can slide a small screw driver between the battery and the clip to release the clip. Sometimes you need a third hand. Tapping the bottom of the belt clip on the edge of a counter while slipping the screwdriver in the sweet spot will sometimes help.
Dec 31, 2013 | Motorola Mag One BPR40 Two Way Radio
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
Battery clips
you have to remove the circuit board from the case. There is a rod that holds the clip in. You have to remove a little rubber cover that keeps the rod from coming out.
You need the part number : PMDN4022AR
Mar 21, 2012 | Motorola Mag One BPR40 Two Way Radio
Walkie talkie batteries don't last
What you have been using are consumer grade walkie talkies. The rechargeable battery packs in them should last a full business day, unless you are in a high use area. This being said, it is also possible you might need to replace the rechargeable battery pack as they usually have just a one year life expectancy. As they start to fail they will go less and less time in a day.
To answer your question about a radio which will go a full business day, any of the business division Motorola handheld radios would work. Radios such as the CP110, BPR40, CP185, and CP200 are all make to go a full day and sometimes more. Their battery packs depending on chemistry would also need to be replaced every 18-24 months.
Best regards.
May 14, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
One of my 1008 walkie talkies will not turn on
the fault radio can be repaired, by contacting the following
www.fastradios.com/two-way-radio-repair.html
www.wireless.com/service-repair.htm.
for your repairs more will be given
Mar 31, 2009 | Radio Communications
56 people viewed this question
Top Motorola Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
richie46
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
