My pilot light went out and when I try to relight it, the flame will light when I press down on the red button by the gas control valve. I hold it down for about a minute like the instructions say but when I release the red button, the flame goes out before I can turn the gas control valve to the on position. What is the problem and how do I repair it?
    President:
  • 1,515 Answers
Hi you will need to replace the thermocouple. This is the copper tube that screws in to the gas valve and goes back and mounts along side of the pilot. Most will pull straight out. When they go out, the pilot will light when you hold the red button down, but as soon as you release it off it goes. You can but this thermocouple at any hardware store. They come in different lengths, But I would get a 36" one. They will coil up so they wont be in the way. Its better to have a longer one then one that's to short. Make sure the tip is in the flame, or it will do the same thing. It has to get very hot to keep and produce milivolts to keep it on.Please don't forget to rate me on this as I know you will be kind. This will solve your problem for sure.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Posted on Sep 10, 2010
Relight combi pilot light?
These are designed not to light once the thermocouple fails.the thermocouple has a small wire that positions in to the pilot light which checks the pilot is on and keeps the gas governed.once the temperature drops it shuts off the gas to prevent a build up of gas in a room where a pilot light has gone out.this is why you need to hold the button in on reignition to allow the thermocouple to heat up so the gas keeps open.
Try to relight by turning on the gas ....pressing down and holding the button for at least 10 seconds whilst firing the piezo to ignite flame.do not release gas button for at least 10 seconds then slowly release.if the flame on the pilot will not stay alight....then it is likely the thermo has failed.try cleaning the metal wire that is above the pilot jet.still no joy then it needs replacing.hope my comment is of help...please vote.
Feb 19, 2015 | Water Heaters
Why does my pilot not have any gas pressure?
This is a safety feature built in the gas valve to be sure gas is not escaping. On most you must hold down the valve knob while lighting the pilot light and HOLD for up to a minute so the thermocouple get hot enough to latch the gas valve on. Read the manual or find one on line, most all gas valves have this safety feature.
Oct 04, 2014 | Kitchen Appliances - Others
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
How do you light the pilot light on the stove? Model 3627391592
A pilot light will be found on natural gas stoves, fireplaces, clothes dryers, water heaters and furnaces. When the gas is turned off, the pilot light will go out on all of these appliances. After the gas is turned back on, you must relight the pilot light before you can use the appliance. Pilot lights are similar so if you can relight the pilot light for a gas heater you can relight the pilot light for a gas stove or any other gas appliance.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions Things You'll Need:
  • matches OR flashlight
  1. Locate the gas valve by following the gas line in the appliance. The gas valve will have a large red button or knob and will be easy to see and will be well marked.
  2. Check for a gas leak by smelling the area close to the gas valve. Listen carefully for escaping gas and do not attempt to light a pilot light if there is a gas leak.
  3. Hold down or press the red button or knob on the gas valve while holding a lit match in front of the opening in the gas pilot line. Continue to hold down or press the red button or knob for several seconds after the gas ignites to allow the thermocouple (the sensor for the appliance's thermostat) to heat up.
  4. Repeat step 3 if the pilot light goes out after you release the button or knob. In most cases, the pilot light goes out because the thermocouple did not have enough time to heat up, so give it a few more seconds.
  5. Make final adjustment of the gas flow to the pilot light by turning the red knob. In some cases, no adjustment other than "on" or "off" will be needed.
  6. Turn on our appliance to make sure the pilot light ignites the main gas flow. Replace any covers or close any access doors to the gas valve.
Hope this help?
Thanks for using fixya.
Nov 23, 2010 | Kenmore Kitchen Ranges
Pilot lite went out and will not relite
The thermocouple is not functioning. The t/c is the small (sensor) tube that the flame touches and should have a small copper tube (capillary) extending to the gas valve. (IMPORTANT: The capillary tube should not have any kinks or crimped places...Only gentle bends. A crimped tube will require t/c replacement.) The flame will deposit a coating (minerals) that will insulate the t/c and prevent it from working. Clean the sensor with steel wool, fine sand paper (emery board) or scotch pad. Now try to relight the pilot making sure the t/c sensor is contacted by the flame, if not, shut off gas and adjust. Once aligned and contacted by pilot flame, hold for a minute, allowing the t/c to warm up fully and signal the gas valve to operate when knob is turned from pilot to operate.
Jul 16, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
AFTER LIGHTING MY RICHMOND 6G40-36F1 WATER HEATER IT LIGHT FOR A FEW SECONDS AND THE FLAME AND THE PILOT LIGHT GOES OUT. WHAT CAUSE THIS TO HAPPEN?
There is air in the gas line. The best way to get the air out, is with the gas on, loosen the nut that attaches to the gas valve and make sure you can smell a little gas, then reattach the gas line, making sure everything is tight, and then relight the pilot making sure to hold the pilot light button down for at least 1 minute. Please rate
May 24, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light went out but will can,t get it relit it only stays on as long as I hold the button down
Is the thermocouple in the pilot flame? & does it get hot [glow red] If not adjust position until it does & make sure it's clean
If thermocouple gets hot but no relight, replace couple
Oct 26, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Pilot light gone out. How do I relight? Which
In general, large button from gas valve push in & hold 20-30 secs at same time push electronic lighter/ignition button to light pilot. Remember to hold in only gas button. the pilot light heats up a thermo couple [u can see this in the flame] and when hot enough allows the main gas through and the pilot to remain on.
If not then either thermo couple not heated for long enough or
it may need replacing
Oct 22, 2009 | Bosch Water Heaters
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
