Question about Dell Latitude D830 Notebook
My computer won't start normally and I push f8 and click enter on the safe mode but then it goes to a black screen with typing all over it, how can I fix that?
    Guru:
  • 1,082 Answers
The black screen is listing the drivers that windows loads. This is normal in safe mode. If the listing gets stuck on the last line and seems to freeze, you have a corrupt driver/system that needs repaired.
You can do a system repair if you have the proper disk. Dell sometimes provided that disk. This site provides details on how to do a system repair. You'll need a DELL OEM OS disk, not just any old CD from a friend.
http://www.techspot.com/vb/topic8356.html
Posted on Sep 10, 2010
Enter system password
Which operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
or
Click "Start," then select "Run." In the text box displayed, enter "control userpasswords2" and press "Enter." This opens a configuration window.
Click the user for whom you want to disable the password login.
After selecting the user, remove the check mark labeled "Users must enter a username and password to use this computer."
Click "Apply."
A dialog box will prompt you for the password.
Enter the user's password to authorize the changes and press "OK."
Reboot your Windows XP computer.
When it shows the list of user profiles, click the user whose password was disabled.
You should be able to log in without a password.
Jan 22, 2014 | Dell Dimension 5100 (D51L1) PC Desktop
Change password
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
I had to launch start up repair and the battery died half way through... The laptop now says "Computer build error. File exception failed to find c:/ (etc)" and it won't turn on, just...
Step 1:
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 07, 2013 | Computers & Internet
WHERE DO I FIND SAFE MODE IN LAPTOP OF HP 6735s
Enter Safe Mode at startup Follow the steps below to start Windows Vista in Safe Mode.
  1. Remove all CDs and DVDs from the computer.
  2. Restart the computer.
  3. At the first screen on restart, before the HP or Windows logo appears, press the f8 key repeatedly.
  4. When prompted, select the Safe Mode with Networking option.
  5. Log onto the computer with a user account that has administrator rights.
Enter Safe Mode when PC is operating If the computer can boot into the Vista operating system, follow the steps below to enter Safe Mode.
  1. Click Start , type msconfig in the search field, and then press the enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Diagnostic startup .
  3. On the Boot tab, select Safe boot and click OK .
  4. When prompted, click Restart to start the computer in Safe Mode. If the computer does not restart automatically, press the Power button to turn the power on.
  5. On the Tools tab of the System Configuration window, select and launch the desired diagnostic tool.
The computer is now operating in Safe Mode. Exit the Safe Mode After completing the required troubleshooting and repair, follow the steps below to exit Safe Mode and return to normal operation.
  1. Click Start , type msconfig in the search field, and then press enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Normal startup and click OK .
The computer restarts in the normal mode.
May 18, 2012 | HP Compaq 6735s Notebook
Black screen system disable service tag
Start the computer in safe mode and run System Restore:
Click the Start button Picture of the Start button, click the arrow next to Shut Down, and then click Restart.
Do one of the following:
If your computer has a single operating system installed, press and hold the F8 key as your computer restarts.
You must press F8 before the Windows logo appears. If the Windows logo appears, try again by waiting until the Windows
logon prompt appears, and then shutting down and restarting your computer.
If your computer has more than one operating system, use the arrow keys to highlight the operating system you
want to start in safe mode, and then press F8.
On the Advanced Boot Options screen, use the arrow keys to highlight Safe Mode, and then press Enter.
Log on to your computer with a user account that has administrator rights. When your computer is in safe mode, you'll see the words Safe Mode in the corners of your monitor.
Click the Start button Picture of the Start button, type "system restore" in the search box, click System Restore,
and then click Next. Administrator permission required If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Choose a restore point when your PC worked as expected, click Next, and then click Finish.
Use system utility software like RegInOut after restarting windows normally. It will repair corrupt registry and windows files.
Jan 02, 2012 | Dell Inspiron Mini 10 Netbook
Black screen fikring
Jan 02, 2012 | HP Computers & Internet
Black screen hp 520
Click the Start button Picture of the Start button, type "system restore" in the search box, click System Restore, and then click Next. Administrator permission required If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Jan 02, 2012 | Computers & Internet
Need help please and thank you
For that you need to fix error on harddrive.
For that You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 05, 2010 | Compaq Presario 5000 PC Desktop
COMPUTER GOES TO COPYRIGHT PAGE NOT WINDOWS
Push F8 before the splash screen loads - start pushing it the moment you start your computer. You should get a screen that allows you to start in safe mode. Once you've started in safe mode, try rebooting and see if you computer comes up normally.
Apr 04, 2009 | Compaq Digital PC 3100 PC Desktop
Black screen on my Acer Aspire 3680
when you start the pc tap on the f8 key and choose safe mode from the menu then hit enter twicw, if your pc will start up in safe mode, then you can click start, then type MSCONFIG in the search box and hit enter ( or click start,all programs,accessories,Run, then type msconfig and hit enter) if you click on the startup tab, you can see everything thats checked is starting with windows, you ca uncheck all of these, and by repeating the steps above, check them back one or two a time, until you find the offending program. Google pacs-portal.com for an excellent site that will tell you what all the startup entries are and if you need them
Mar 30, 2009 | Acer Aspire 3680 Laptop
Dell Latitude D830 Notebook Logo
124 people viewed this question
Alun Cox
