Question about Aloha Housewares (93645) Ceiling Fan
Do you have a 52" White Blanco that comes with a remote control? If not that model, any others that have a remote?
How can I replace the receiver on hunter tribeca ceiling fan
The black & white on one end go to the house wiring. The other three go to the fan wiring. Black to black, white to white & connect last two wires together.
Aug 17, 2014 | Hunter 52" Ceiling Fan With Light And...
How to eliminate receiver/transmitter in hunter 28425
Open the box at the bottom of the ceiling fan, where the switch is. You should find the receiver inside there. You'll find one white wire connected to it, and two black wires also connected to it. Remove the white wire completely or cap it off with a wire nut. Connect the two black wires to each other with a wire nut. Reassemble the ceiling fan. If the problem was the receiver, then the problem is now gone because the receiver is gone.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
How to attach and wire my controller for my remote control
What model do you have? If it is an add-on remote, then follow instructions here:
1) Black on end of receiver to black in ceiling.
2) white ( next to black ) to white in ceiling.
3)Other White to white in fan.
4) Black to black in fan.
5)Red or black w/ white stripe to blue or black w/ white stripe.
Oct 16, 2013 | Hunter 52" Ceiling Fan With Light And...
Remote control fcc id: KUJCE9001, MODEL: bcf-00i9x2
Hi there
we need some assistance with our remote our fan has reversed direction and we cannot get it back
Jul 21, 2012 | Hampton Bay 52 In. White Redington...
We have a ceiling fan Apollo 52' Model 355-6788 but we don't have any instructions on how to put it up. Please send us instructions on how to do this.
On the remote part that goes inside the fan, it has five wire on it. One Red wire marked L goes to black switch wire from switch or Hot wire. Other Red wire goes to Net. wire from switch.or feed.Then you have A black, a blue & a white. They connect to wires from the fan. When finished connect turn light switch on, leave on & used remote control. Top left button controls the fan on/off. bottom left button controls light on/off.dimmer. There you go, all the know how to connect remote & fan/light up. Good Lucky.
P.S. You will need to buy a 9v battery for the remote, it doesn't come with it
Aug 13, 2011 | Heating & Cooling
Fan not responding to remote
Check to see if the remote switches of your hand held device match the switch setting in the fan assembly
Sep 15, 2009 | Hampton Bay 52 In. White Redington...
Installing a universal remote on a ceiling fan.
your remote modual should have two or three wires coming from the unit on one side to go to the fixture and three on the other to hook it to power , the three should be to connect to the black (power), the white (Neutral) and green (ground), now the unit has power. The two or three coming from the other side should be a white and two other colors or two the same , black, red, or blue, The white connects to the fan white and the other two go to, one the fan and two the light. Any questions E-mail me...hwyhmmr hotmail
Oct 22, 2008 | Hunter 52" Ceiling Fan With Light And...
Aloha Housewares (93645) Ceiling Fan Logo
29 people viewed this question
Top Aloha Housewares Dryers Experts
Mike Carew
Gene Haynes
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
