Question about E-Machines eMachines Desktop PC
I have an emachine that is 1.5 years old. The problem is that it locked up/froze and was not able to turn off so I turned off the power strip. Now I cannot get the computer to start, it sounds like the fans start up for about five seconds then the system shuts down. Anybody have any ideas?
    Scholar:
  • 128 Answers
Try to disconnect the cables connected to the mother board from your power supply then put it back in, then remove the CMOS battery and put it back in then try to turn the computer on..If it's still the same this means you need to purchase a new power supply.
Posted on Sep 10, 2010
My computer will not turn on. My niece turned off my power strip and now my pc will not boot back up.
try putting the computer plug in a different wall plug sounds like you have a worn out plug causeing your problem.
Oct 05, 2009 | E-Machines eMachines Desktop PC
Printer locked on printing
Try changing your firewall, it worked for me. I got my 926 a year ago with my Dell and had no problems until I replaced my expired Norton w/a freebe that was very aggessive then the problems started. Would not comunicate sometiimes and when it did it printed once than froze. Would not delete printed doc or print the next. I remembered that McAfee made my old Emachine freeze or crash. Put Norton back on and no more problems. Hope this helps you.
Jan 29, 2009 | Dell 926 All-In-One InkJet Printer
My hp desktop computer will not turn on
If you cant see or heard any boot up sounds, fans and especially if you dont see any power or green led lights at all ;
If your power cord is plugged into a power strip or surge protector, power cycle your strip or surge protector by turning off and on.
If power outlet has a wall switch make sure its on
Check that your power cable is securely plug in to both ends
Check that at the back of computer, specifically on the back of the power supply unit that the switch is on "1" position and NOT on the "0" position ( 1 is "ON" , 0 is "OFF" )
Check that the power outlet is not damaged by pluging in another good known device (such as a blowdryer, shaver, lamp, radio, etc, etc) to see if its the power outlet or not.
Can you see power or green led lights and hear the fan on but no display ? If this is the case , check your monitor connection at both ends. If they are secured open up your case and see if you can smell any burnt smell or check that all cards especially video cards are properly seated.
Jan 21, 2009 | E-Machines eMachines Desktop PC
Emachine t5206 adding 2 gig of memory
How much memory are you trying to add?
Nov 08, 2008 | E-Machines eMachines Desktop PC
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
Computer won't start
unplug the power cords and let it sit for about 5 to 10 min. just like the cable box sometimes the brains have to be reset than make sure all plugs a lined up and tight good luck Dawn
May 06, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
42 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
