Question about NorStar M7324 Telephone
WHEN I CAN AN EXTENSION A GET A MESSAGE THE THAT LINE IS NOT IN SERVICE. HOW CAN I FIX THIS?
    President:
  • NorStar Master
  • 860 Answers
The not in service message is given when there is no telephone attached to the intercom number your trying to call. I'd re-check the intercom number your calling, this can be done by using the button inquiry feature on the set your calling. At the set your calling, press feature *0, then press the intercom button on the lower right hand side of the set. The screen will display the intercom number of the set.
Posted on Sep 10, 2010
I need to find out what someone's direct line is. I have an extension assigned with a mailbox but not sure of the direct line # associated with the extension. How can I find out?
This would depend on if the line is a stand alone line only being assigned to one extension or on a PRI having DID service. Do a Feature *0 and check the line buttons. It will show the line number or target line number. With this information you can check it in one of two ways. If it is a stand alone line and provided a line number, access the line by pressing the line and dialing your cell phone to get the Caller ID information. If it associated with a PRI having DID service, you will have to check the target line information in programming. A system administrator or vendor needs to do this.
Aug 30, 2013 | NorStar Lands Phones
Norstar M7310 getting Not In Service message
This message means that the system does not see a telephone connected to that extension. Check the extension that you are calling to see if it is operational. Check the extension number by using Feature *0 and pressing the intercom button.
Apr 05, 2013 | NorStar Meridian M7310 Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    HP LaserJet 3055 .fax not working
    Direct Line:
    1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
    Dial the number and observe weather extension phone is ringing?
    A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
    B. *Extension phone is ringing no message displayed on device replace "LIU" card..
    If extension telephone is not ringing check telephone line..
    No out going faxess:
    *Check line is connected though EPABX , if connected Check..prefix setting..
    *Check out going..
    Best of luck...
    Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
    I have a Panasonic 6.0 DECT Talking ID Caller phone system. I lost my message that callers hear when the answering machine answers the phone. Somehow my granddaughter's voice has been recored and that...
    Making Use of the Voice Mail Service
    From your own extension
    VPS* Extension No.
    Mailbox
    · If you have no password, you can skip the last step.
    * VPS: Voice Processing System
    From someone else's extension
    VPS Extension No.
    Mailbox No.
    Mailbox Password*1 +
    Listening to a Message
    Password*1
    KX-TVA series
    Listen to Message
    Deliver Message
    Mailbox Management
    Automated Attendant
    Message Notification
    Other Features
    End Call
    KX-TVS series
    Listen to Message
    Deliver Message
    Check Mailbox Distribution
    Automated Attendant
    Mailbox Management
    Other Features
    End Call
    VPS Extension No.
    Leaving a Message
    Mailbox No.
    Enter the desired mailbox no.
    To send the message immediately
    Leave a message
    (KX-TVA series)
    (KX-TVS series)
    Follow the guidance
    To set the delivery time
    May 24, 2011 | Cell Phones
    When call goes to voicemail, it says call being transfered
    I understand that you would like to bypass Auto Attendant for your lines.
    On extension 10 or 11
    Feature 00
    Left Intercom, Left Intercome
    #208
    Line 01
    Enter your extension number
    #208
    Line 02
    Do the same for all of the lines.
    Go to your extension to program a voicemail cover button. Without it being on voicemail wont pick up
    Press Feature 00
    Select a button and call it Call Cover press it
    Enter Feature 15
    Feature 00
    Press that button so the green light lights up.
    Test.
    Jun 18, 2009 | Lucent PARTNER18 Corded Phone
    During incoming call the line will go to others extension line.
    Consult an expert he will fix it bcos normally they wont let go their codes.
    Rate this
    Apr 06, 2009 | Panasonic KX-T7730 Corded Phone
    Incoming calls ring on intercom rather than appropriate line.
    Somehow you might have taken the lines off the extension. I would double check that under line appearance, that extension is set to "appear and ring" for each line.
    Dec 08, 2008 | NorStar M7310 Corded Phone
    Changing the LCD
    that is usually caused by a message waiting light being turned on from an extension, the message waiting feature can be used to call voicemail or to call another extension, enter code #409 on ext 214 to cancel the msg waiting light
    Mar 18, 2008 | Toshiba DKT-2020 Corded Phone
    NorStar M7324 Telephone Logo
    Top NorStar Lands Phones Experts
    george  peters
    george peters
    dan4261
    Level 1 Expert
    Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
