Question about Nokia E75 Cell Phone
I downloaded an application named hanghai from dotsis and thereafter the screen often goes black , i recieve the calls but screen is still black.i removed the application via pc suite but the problem persists. please help may phone is nokia e 75
  • 10,421 Answers
My phone basically just started losing applications, when i went to text it isnt showing that i have any conversations, which i know i do, and when i hit the cross to add a conversation it freezes for a...
That shows the memory of your phone is full so try and decongest some information on your phone that you feel you don't need again to create space for you to be able to do some other things on your phone.
Feb 09, 2011 | HTC 7 Surround Cell Phone
My phone samsung GT-B3210, the dialled calls,missed calls and recieved calls cannot be display on call log
Do a Samsung b3310 Master Reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone.
Enter *2767*3855# from the standby screen. (You may need to remove the SIM before it will allow you to type the code in)
Dec 26, 2010 | Samsung Cell Phones
Black screen. Problem started while trying to download latest AVG free. Quick flash said something like 'touch pad not working'. Can i use mouse? Had a black screen prob before with Acer Aspire, so...
1. When you are under black screen condition, if your mouse and keyboard are still usable, and you are lucky enough to have a dialog window (usually "My Document"), use this window to go
C:(or whatever drive that stores your operation system) -> "Windows" folder -> find an application called "explorer", double click and open it. Now you should be able to get your screen back to normal.
2. If you don't have a dialog window, press "Ctrl" + "Alt" + "Delete" together and transfer the screen back to the login page. Click "Task Manager" -> Click "Application" tab -> Click "New task" -> type in "explorer" and then press "Enter" key. Now you should get the desktop screen.
3. Press the Start button (the one with window icon, at the lower left corner), open the "Run" program (if you can't find it in the menu, type "run" in the search bar and search for it). Type "regedit" to open the registry editor.
4. Go to this root:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System
Under this root, you should see a item named "Shell", if the data value of "Shell" is "C:\Windows\Explorer.exe C:\Windows\system32\tlntsvi.exe", here is the MALWARE!
The correct value should be "C:\Windows\Explorer.exe" only, whatever following this command is the bad guy that brings your computer to black screen of death.
5. Now MARK DOWN the NAME of the malware (in my case, mine is "tintsvi.exe"), because this malware is known to have different names. So far I've seen "tintsvi" and "pnkx".
Now delete whatever command that follows "C:\Windows\Explorer.exe". Close the registry editor.
Start "Search" program, type in the malware name (in my case, "tintsvi") and search the remains of the malware. You SHOULD find something in the "Windows" folder. I've found a "tintsvi8973.exe" application as well as a weird file called "Servx.exe" under "C:\Windows\System32" folder. Since "servx" and "tintsvi8973" were created at almost the same time, I believe it is a malware so I deleted both of them.
Dec 23, 2010 | Acer Aspire One PC Notebook
Bluetoot peripheral device not found...i have my
“To find Bluetooth Device, follow these instructions.” 1. Click on the (“Start”) button on the Taskbar. 2. Point, and click on (“All”) Programs in the Start Search window, type: the (Bluetooth Device name), (example): “Dell.” 3. Scroll to find, Name (BTD name) Application / Driver Installer.
4. The (“Name?”), Application and Driver Installer appear!
5. “Scroll to find the “Bluetooth application.”
6. Click on the application to "Highlight," to the right, click Install.
Follow all the instructions thereafter carefully! “Did this solution help?”
Jan 25, 2010 | Computers & Internet
Screen blackout
I am too facting the same issue ...Reverted back to def. settings ...uninstalled all unused / downloaded applications but still screen goes black when i slide the set in / out. and i cannot hear on head set..i need to sweitch on the speaker to make and receive calls all the time
Jan 21, 2010 | Nokia 6210 Navigator Cell Phone
Tv powers up and the screen then goes black..still has sound thou
power pack capacitors are going bad, need to have then replaced.
hope this helps
Apr 06, 2009 | Akai LCT2715 27 in. LCD Television
Direct Tv Receiver No sound Black Screen
unplug the power from the reciever for a few moments. plug it back in and let it load. once its finished turn to channel 201. Usually it the reciever is on an unavailable channel (channel with no programming) when it restarted it will go back to that unavailable channel hince the black screen and no sound.
Jan 01, 2009 | Philips DIRECTV H20 DTV Receiver
Mp3 player download in nokia 6600
visit this site and sine up and you can download mp3 player for (s60 searies)from this site-www.dotsis.com
and after this past this application in your memory card.thean on your mobile and press menu key andpress tools folder then open application manager and open memoryby moving joistic toright side and find that application.and press ok button(install).Thats it
Jun 01, 2008 | Nokia 6600
Nokia E75 Cell Phone Logo
85 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
