This draytek Vigor 700 access point needs to be configured as a WDS extender, however although it can be reset from the button, I can't log onto it either via ethernet cable or wireless. The draytek website (there's no other support option) says to use 192.168.1.2 but this doesn't work. I've tried all numbers between 192.168.0.0 to 192.168.3.3 with no luck. Tried all this with PC and mac.
rahul26485
  • 611 Answers
SOURCE: WEB configuration problem.
http://support.dlink.com/emulators/dwlg700ap/ i give you this web page address go it is a helpful to .
Posted on Jun 03, 2008
JackHeath
  • 1049 Answers
SOURCE: Netgear access point cant open configuration page
Typically you should be using configuration software until a real IP can be setup and you either address it statically or turn on DHCP. As for the gateway and other information, on a wireless gateway, it should all be routed through the network. Also, I think you have to be wired to the WAP to access the config page, I don't believe it can be seen over the wireless connection as a security feature.
Posted on Aug 02, 2010
alex8642
  • 21 Answers
SOURCE: 4350 Small Network Access Point's web-based configuration tool
If it is trying to connect to the internet when trying to get to the tool, you have to get a direct link to the tool. You might find this on a forum somewhere. It might also help to update your firmware, this may solve your problem immediately. The only problem with routers is that they are built to connect to the internet.If you don't have the internet it is a tedious job to get access to your access points settings. Just get the link to the page and you should be able to change your settings then.
Posted on Feb 24, 2007
SOURCE: problem using wireless access point to conect desktop PC to WLAN
I have solved the problem:
- first, I had to change the management address in CF-WFAP into address that could be recognized by the router (i used 192.168.1.2),
- DHCP turned off, and set default gateway and DNS to 192.168.1.1. as in router, computer IP was set to 192.168.1.xxx, push "apply", change web address to new one,
- set AP mode to station-infrastructure, push "apply" buton to restart AP,
- set security to same security as in router and copy key into proper field, push "apply" again to reset the AP
- finaly check wireless station around and choose the router (same encription)
Posted on Mar 22, 2009
toac990
  • 838 Answers
SOURCE: Router working as Access Point, unable to access via we browser
Please try first plug out the router and plug in again then press & hold the reset button till the power led become red and release. If that doesn't work, plug out the router, pressing and holding the reset button plug in the router.
Let me know the result please.
Thanks for joining Fixya.
Have a good day.
Posted on Feb 22, 2010
Testimonial: "Thanks for your answer. It worked"
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
I cant access the 192,168,2,1
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-... Hope i helped you.. great day to you.
Jan 30, 2013 | TENDA A3 150Mbps Wireless Range Extender
Hi Team, I have a Draytek Vigor 2700 Router. I have redirected ports 80 , and 34599 to view my DVR cameras at my office. I have a static IP and i can successfully log into my DVR via HTTP port 80,...
It is an issue the Draytek and your phone.
Draytek displays as a web page. It uses HTML or XHTML
In order to see it on your phone it needs to be coded in XHTML Mobile 1.0
Jul 02, 2011 | Draytek Vigor 2700 Adsl2/2+ Router 2 Vpn /...
I have two netgear routers and wondered if i can make them work together to extend my wireless internet range e.g. using them as repeaters (rather than having only one turned on depending on the area of...
i dont believe you can do such thing but you could run two routers and log onto each individually. Just like your at home using the laptop and you go to a friends 20 miles away and you take your laptop and it will recognize his wireless allowing access.
Jan 06, 2011 | NetGear DG834G Router
I want to extend 2640t router's range by using 3200AP as wireless extender. Could establish handshaking between two devices using physical (cat6) cable but not wireless connectivity. In which mode 3200AP...
yes u can just use the same range ip address for both device like 192.168.0.1 for dlink and 192.168.0.2 dor airplus.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 31, 2010 | D-Link AirPremier DWL-3200AP, AirPlus G...
WDS Setup
In a WDS network, all the access points need to be in WDS mode, and one of them needs to be wired directly to a routed internet connection.
Here is a very good detailed tutorial on how WDS works and how to configure and troubleshoot your own WDS network:
How To: Setting up WDS Bridging / Repeating
Jun 03, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
Lost my network key and need to to set up a wireless network. What do I do
Do a backup on the router and get the settings
Part I : Backup
1. Logon to Router Web Configurator page, choose System Maintenance >> Configuration Backup.
2. Click the Backup button.
Part II : Restore
2. Click Browse button, choose the config file that you'd like to restore then click the Restore button.
3. If the restoration is successful, there will be a Congratulation window popping up. Please click the Restart button to apply the updated settings.
Please be advised not to restore the config file back up from former firmware version. While firmware version is upgraded, please configure Vigor Router's settings again manually.
Jun 24, 2009 | Draytek Vigor 2600VG Wireless Router...
Draytek Vigor 110 modem
There is no default username or password to access the Vigor routers. Reset the router to clear any previous settings from its memory. Default IP Address is http://192.168.1.1 Manuals and firmware is available from the device maker.
May 17, 2008 | Draytek Computers & Internet
Bad reception
If your old router has an option to become a relay for a specific Access Point.... most do not have that option unless its a 3rd party firmware
Apr 28, 2008 | Draytek Vigor 2600We (Vigor2600WE)...
What is WDS?
Wireless Distribution System (WDS) allows you to make a completely wireless infrastructure. Normally, the access points must be connected with a wire (LAN). These access points create cells allowing a wireless connection. The WDS feature allows the access points to be wirelessly connected. This feature is normally used in large, open areas where pulling a wire is restricted or not cost effective and in residential circumstances. If the structure utilizing an access point is too large to cover using one AP, a second AP would be used as a wireless repeater. The WDS has forwarding functionality for extending the range of an AP. By setting up an extended service set (ESS) between access points. Stations can intersect with any AP of this ESS and move between the coverage of both APs while the higher layer network connection remains intact.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
