Question about Kodak EasyShare V1003 Digital Camera
I'm taking pics in an underground tunnel where the area lighting isn't all that great. My pics are coming out not as clear as I would like. What should my camera settings be. Rick
    Brigadier General:
  • 11,967 Answers
Set the ISO to a higher setting and use a tripod if you can.
Posted on Sep 10, 2010
How to Get the Real Megabuster on Deadrising?
    -Head straight for parking lot in Leisure park-north west area of park
    -Take red sports car from parking lot and drive it into the tunnels-which will be just to the left
    -Drive to white/grey car-go right, take 1st left, 2nd right, and follow tunnel round bend and head straight all the way to the end
    -Take white/grey car
    -Drive it to van-head straight back the way you came round bend, first left, head right where you can. You will come to the entrance to tunnels but just continue past and follow tunnel all way to the end
    -Take van
    -Drive van back to either red or white car
    -Repeat till you have Zombie Genocider achievement
    -Play game normally till end
    -The real megabuster will now spawn in security room
Oct 20, 2016 | Video Game Consoles & Games
Tip
Infocus 4805 Light Tunnel DIY Replacement Option
About a year ago my light tunnel failed and I was able to fix it thanks to info on the net. Then about a month ago I decided to try to finally replace my Light Tunnel. Mainly because replacement parts are discontinued and manufacturer repair is way too expensive. In the process of failing, I was able to find a great low cost solution that's pretty easy to fabricate. My post is here:
www.avsforum.com/avs-vb/showthread.php?t=1304694
If you have never opened your Projector go here:
http://www.avsforum.com/avs-vb/showthread.php?t=556431
It's regarding Dust Blobs, but it has pics to show how to disassemble the unit.
So as for the Tunnel and getting to it...here is a thread for a different model PJ, but the layout is very similar:
http://www.avsforum.com/avs-vb/showthread.php?t=618877
Hope this post is helpful to you :)
on Jan 07, 2011 | InFocus ScreenPlay 4805 Multimedia...
The audio system is still not working after
take the acura to a tunnel while driving have someone put the code for the radio in the radio will work or find a underground parking lot
Jul 07, 2010 | 2003 Acura 3.2TL
I have a Sony dsc s600 that works great except all the pics come out totally black. Is this caused by a bad ccd?
not usually, it is caused by under eposure make sure you have the settings of the ISO to a level that is complimetary to daylight
set it to 100 and to say scene and take a few pics. Donload them on to the PC and with the software look at the graph that accompanies each pic to see what is happening with th light factor. You can drag areas of the graph and the pic will alter on screen.
Perhapsa the shutter is not opening.. look in the lens and press the button to see if the shutter actuall opens and shuts
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
Reddish line to the right of the screen. replaced bulb yesterday.
the light tunnel is collapsing. you can get the part from an infocus service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 17, 2010 | InFocus ScreenPlay 4800 Multimedia...
Samsug rear projection tv, everything looks green
Dust accumulation in color wheel, light tunnel, chip area can cause green tint.
It is very delicate area, light tunnel and chip can be easily damaged. Remove light engine assembly and color wheel. Blow dust out. Re-assemble. If the gasket around the color wheel housing is not replaced in the right position, or the housing screws not tightened correctly dust will contaminate the color wheel/light tunnel area.
Call someone that has done it a few times. If near Calgary, call me.
easyab
Jul 14, 2008 | Samsung HCM4216W 42" Rear Projection...
Dark edge of screen
there is a part inside the engine(the part that produces the picture) that is a mirror tunnel. The actual part name is "light tunnel" this tunnel takes the light from the bulb and compresses it into a smaller beam of light that is then shined onto the DMD(million mirrors) this produces the picture on a DLP TV. this mirror tunnel is glued together on all edges. One edge of your "light tunnel" has started to come unglued and has slipped a little. This causes the slightly dark area usually on the left side of the picture that you see. the light tunnel can be replaced as a single part. much cheaper than replacing the whole engine.
Jun 19, 2008 | Samsung DLP HL-P5663W 56" TV
Lp70+ display shows a solid black vertical line
the light tunnel is either collapsing and blocking the light going through it (and needs replacement) or the vertical/hoizontal adjustment of the tunnel. if you take the lamp out and move the colorwheel (with a pencil eraser) to the clear section, you should be able to see a square through it. if part of the square is blocking the middle, the tunnel needs replacing.
by the way, on some projectors the light tunnel is called an integrator rod.
Jun 17, 2008 | InFocus LP70+ Multimedia Projector
HLR4266W
how dark? can you see anything throught the shading.. still might be a cap in the video out circuit but the one Im thinking of shades the right side and brightens the left.
sometimes RF or HV arching causes shading on left, mute your sound and listen for sizzle noise in the back.
Jan 26, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Kodak EasyShare V1003 Digital Camera Logo
308 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
