Question about Microsoft Xbox 360 Arcade
My xbox blinks red. - Microsoft Xbox 360 Arcade
  • 4,102 Answers
Hi you have got the dreaded red ring of death, this is very common with all xboxes and their are people out their that will fix them for you for a fee.
their is nothing you can do yourself to solve this problem as its a case of taking the xbox apart and removing the heat sinks and the x clamps and fitting new parts and new heat sink paste, this is a big job and requires special tools. so its not for the novice to do.
i do the repairs to these on a regular basis and 8 out of 10 i fix work again but others tend to be to far gone.
any way the reason you are getting this warning light is due to it over heating, check the date on the sticker on the back of the xbox as it is covered by warranty for 3 years for this exact fault so if its less than 3 years old go to the xbox website and get them to replace it for you, if its outside this time then you have 2 options you could either repair it or sell it.
you can buy repair kits and get the instructions off the net but without having done it before it can by really hard to do and you could do more harm than good.
when they built these they used cheap parts and cheap heat sink paste now over time this causes it to over heat and then you get the dreaded red ring of death and this shows you the either the gpu or cpu chip has over heated.
now the repair involves taking the xbox apart which is not easy but can be done you need to then remove the x clamps and then remove both heat sinks. once their removed you need to clean them up and remove all the old heat sink paste and use new paste, you also need to get xbox rrod repair kit as you wont be using the cheap x clamp bits anymore these will go in the bin as this is what caused the problem in the first place.
let me know what you would like to do or if you need further assistance ok
i also be damaged xbox's but im based in UK
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 10, 2010
My xbox is blinking red instead of green
that happened to my friend and he has told to put it in the freezer for about an hour . it is called red ring
Jan 04, 2014 | Video Game Consoles & Games
Blinking red light.Checked all cables. I replaced Hard drive...still problem exists. Wondering if power supply could be problem
When one light from the four lights ring itself changes from green to red, it means that a general hardware failure has occurred or is imminent. Blinking of one red light with an error message like E66, E67, E68, E71, E74 or E77 means a repairable problem while the one red light blinking without error message means some critical or irrepairable problem. The problem can be avoided by restarting the Xbox 360 console but if you have not received any error message with one blinking red light then the problem is irrepairable. The console will behave the same way and you should understand that one or more of the hardware components in your console have stopped functioning due to hardware failure. If you receive an error message with one red light blinking then the problem is reparable and the system will definitely start working. It means that there is some hardware problem with the Xbox 360 console connection occurring due to the misplacing of cables in the ports. Turn off your Xbox 360 and disconnect all cables, now reconnect the cables and switch on the Xbox hope this helps.
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
3 blinking red lights
u my friend hav the 3 red rings it just means that u need 2 let ur xbox rest 4ahale ur lucky its not tha ring of death
Dec 20, 2009 | Microsoft Xbox 360 Console
My xbox 360 is blinking red .
that is the legendary red ring of death look that up on google
Nov 23, 2009 | Microsoft Xbox 360 Console
Blinking red light
When someone say that his/her Xbox is having Blinking red light problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's blinking red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 18, 2008 | Microsoft Xbox 360 Console
Xbox 360 with 3 blinking red light
The xbox keeps blinking the red light and it doesn't show anithyng on the screen.
Oct 19, 2008 | Microsoft Xbox 360 Console
Flashing red ring on x box 360 console
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
I get red rings when i turn on my xbox 360
3 red light blinking
When the three red lights are blinking, that means that there is a hardware failure. If your console is under warranty, than you can call 18004MYXBOX, and they will fix it for you for free( including shipping). By the way all of the consoles are under a 2 year warranty for this problem so it will be free.
Apr 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Arcade Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
