Auto charging faault - Computers & Internet
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 19, 2010
Will not charge and actually seems to discharge when plugged in to auto charger
Charge the unit overnight with a high power usb charger, 2A or above. If it turns on after that, check your auto charging cable. It should have a red led that illuminates if it has power. If it does not, then it is either the cable or a fuse blown in your car. If the gps still does not turn on after chargning overnight, you have a batter issue. Amazon sells battery kits.
Apr 06, 2015 | Garmin nuvi 2599LMTHD 5" GPS with Built-In...
Kia spectra steering wheel
it will have an air bag i take it feel behind the steering wheel you will feel two holes these holes are the way you take off the air bag depending on weather it has a star drive screw or a normal posey screw put the driver into these holes take out screw (some screws dont come out all the way but you can tell if there loose ) air bag should come off remember to take off battery lead and let it power down for a few minuets before yo u remove the air bag if not the air bag ecu will thing there is a faault and you will have to get it reset the nut for the steering wheel will be there losen it and remove wheel hope this helps ivan
Oct 02, 2012 | 2007 Kia Spectra LX Sedan
1280 auto charging solution
My nokia 1280 auto charging plz help me
Mar 25, 2011 | Nokia 1110 Cellular Phone
My bike starts and idles fine, however when I engage the clutch it dies. it is actually an xv500k but that was not in the list of options.
possible that you have a weak fuel mix, dirt in the fuel or possible ignition faault with wrong timing, check this out
Jun 29, 2010 | 1983 Yamaha XZ 550
System Error code 09 038 46 24363
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 07, 2009 | Xerox Phaser 8500DN Printer
Paper jam canon mx850. I cant find the paper.
The error indicates a black ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
If you ever buy any Xerox ink and you get a cracked ink stick call Xerox cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif800-835-6100cb_transparent_r.gif and they will replace it free of charge. Otherwise you risk this problem.
Hope this helps.
May 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Hope this helps.
May 30, 2009 | Xerox Phaser 8560N Laser Printer
Error code 09,036.44:10394
Sep 15, 2008 | Xerox Phaser 8500N Printer
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
