Question about Samsung Refrigerators
The freezer (top) is working properly but the refrigerator section is not cooling. samsung rs233
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 10, 2010
I have a 2013 Samsung frig model rf28hfedbww/aa. The top part is not cooling The freezer is ok
Freezer supplies cold air for the fridge section.. Check fridge gasket for tight seal, operating freezer fan along with proper operation of damper mechanism which directs flow of cold air into the refrigerator.
Sep 04, 2017 | Samsung Refrigerators
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
My Magicchef fridge is not cooling but freezer works perfect..How do i find the problem
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Jul 28, 2011 | Magic Chef CTB1502AR Top Freezer...
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
Refrigerator Compartment not cooling properly: freezer compartment working properly
Check the freezer section for frost build up, there is probably a problem with the defrost cycle. 1 of 3 things defrost bi metal would be the likely problem.The back panel in the freezer should be removed to see if there is too much frost.
May 01, 2009 | Frigidaire FRT18S6AW Top Freezer...
Amana (freezer on top) not making ice; fridge warm
I would be calling the store from where it was purchased it should be under warranty. If the ice maker is not working the freezer is not getting down to proper temp. therefor the refrigerator does not cool because all cooling takes place in the freezer, there is a damper between the refrigerator and freezer that allows air through cooling the refrigeration section. Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap.coil is icing up and there is no air blowing into the refrigerator. This is the most common problem.
Oct 20, 2008 | Amana ATB1836AR Top Freezer Refrigerator
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Kitchenaid Side by side refrigerator section is not cooling the freezer is over cooling
SINCE THE FRESH FOOD SECTION GETS ITS COOLING BY AIR CIRCULATION FROM THE FREEZER, THERE MUST BE A RESTRICTION IN AIR FLOW SOMEWHERE. CHECK THE FREEZER EVAPORATOR AND FAN TO BE SURE THAT THE FAN IS RUNNING, AND THE EVAPORATOR IS NOT RESTRICTED WITH FROST. CHECK THE DAMPER OPENINGS FROM THE FREEZER SIDE TO BE SURE THEY AREN'T ICED OVER. IF IT IS AN ELECTRONIC CONTROL, CHECK THE THERMISTOR CIRCUIT FOR PROPER RESISTANCE. TECH SHEET INSTALLED BEHIND THE TOE PLATE SHOULD GIVE THAT INFORMATION.
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
138 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
