Question about Acer Aspire One PC Notebook
My acer aspire one d250 when you worked Become screen white. the close and open and working properly but after a while the problems repeatedly
    Problem Solver:
  • 9 Answers
MY ACER ASPIRE ONE D250
Posted on Sep 10, 2010
Is it possible to swap a bad acer netbook aspire one d250-1026 hard drive for a aspire 580t acer labtop hard drive
Yes but it won't work properly until you do a fresh install with drivers from acer.com.
Oct 05, 2014 | Computers & Internet
Does this computer have a dc power jack plug or cable
Acer Aspire One D250 AOD250 has cabled dc jack, do not need to solder, plug in and your laptop will work, view this page for reference: http://www.lapdiy.com/acer-aspire-one-d250-aod250-wire-harness-power-jack-dc-in-cable-p-26502.html
hope this can help you!
Dec 27, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
How do I connect my acer aspire 5050 to TV?
Since the Acer Aspire One D250 only has VGA output for its video, you will need a VGA cable to connect between the D250 and a TV that accepts VGA input as a video source. The sound is separate. A mini-stereo jack on an audio cable with two RCA phono plugs on the other end would be used to connect the D250 audio output (usually used for headphones) to the left and right audio inputs on the TV. You may need to use the TV setup screens to select the proper video and audio sources. With the TV on and proper video source selected, you now should be able to press Fn and F5 to get a menu in the middle of the D250's screen that allows you to select the video destination by holding down Fn key and pressing the F5 key repeatedly. The single large screen icon (3rd one from the left) is the one to select video output to VGA port only which would send it to your TV. The sound on the D250 does not need to be selected but you may wish to adjust its level and/or properties to be more suitable for TV.
Jan 19, 2011 | Acer Aspire One D250 Netbook
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
Acer aspire one # D250-1958. When i cut it on it just has a blank white or gray screen and it will not leave
Hi this is a common problem with all laptops/netbook/flip phones and all slide phones.
the problem you are having is with the data ribbon that keeps the screen connected with the circuit board in the bottom.
now this ribbon has several single strand copper wires running through it and each time you open and close the notebook this ribbon bends so you keep the connection with the screen, then over time these copper wires become brittle and break and this is whats giving you the white screen.
your laptop is working but you just cant see whats going on with it as the data is not getting to the screen.
now as this is such a common problem is makes the part itself cheap to buy and cheap to have fitted, how ever its not the kind of job you can do yourself as you need special tools to take the notebook apart and also tools to remove this ribbon.
the cheapest place to have this done is one of those small computer repair shops these will be a lot cheaper and quicker than the big branded stores as the big stores will send it off and charge you a lot more.
have a look in your local phone book and look for computer repair shop and ring around and get a few prices and ask how long its going to take, then choose the one that offers the best deal and the quickest time.
its not going to cost much and is worth doing as it would solve the problem and get your notebook working as it should do.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 01, 2010 | Acer Aspire One PC Notebook
Ace aspire d250 wireless switch is not working
Read these carefully and do as the manual describes..
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
May 30, 2010 | Acer Aspire One PC Notebook
Acer aspire 4530 - crystal eye problem
  • Hi has the webcam ever worked? If so what happened to stop it working? The webcam on Acer notebooks is part of their Vista software so if you uninstalled by accident you would need to reinstall the application that runs it aswell. Acer notebooks have a useful utility called Acer Erecovery Management which you can use to reinstall. Goto Start, All Programs, Acer Empowering Technology Acer Erecovery Management.
I hope this helps
Apr 04, 2009 | Acer Aspire 4530-5889 Notebook PC
Acer Aspire One  PC Notebook Logo
272 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
