Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Thanks, I am serarhing for the part that allows
Thanks, I am serarhing for the part that allows the air from the freezer go to the referigerator side of a side by side, model# GS5DHAXVY00 or either the last two numbers are OO. Serial# 2328098 Type 2555A, numbers from part of plastic cover are: W10134216 and EG-100084 120v 4w and 218081M 60 Mz Motor Name is:Synchronous Motor = KT-100084 & 50SM21-1-151B emz. Thanks much in the matter of finding this part. The door would not stay open or closed, but open partly and click back down... Thanks, Huey
    New Friend:
  • 5 Answers
Same thing happened to me. Ice built up on your door keeping it from opening completely. The motor stripped a gear when pressing the door against the ice. You have to either replace the motor or the whole door unit depending on which is available. I have not found the part yet.
Posted on Jul 10, 2013
  • Charles Law Jun 23, 2014
    I ended up purchasing a synchronous motor on eBay and modifying it to fit. Cost me less than $5 it total :) I has been working for over a year.
fridgetech
  • 473 Answers
SOURCE: whirlpool pin retainer is broken on ice dispenser
You don't have to replace the whole door. There is a kit that comes with instuctions. You can get it at www3.sears.com and the part # is 2206423 and switches over to #8201649 and is called door mechanism assembly. It is $42.99. Use # 2206423 for lookup purposes. Hope this helps.
Posted on Oct 09, 2007
  • 65 Answers
SOURCE: Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Posted on Feb 16, 2008
SOURCE: whirlpool refridgerator 362L model No.WRN38RWG6 need
yeah I alos need some spares fro min
Posted on Nov 10, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
Freezer and referigerator only cool, no cold
Sounds like the freon is low. Needs a repair man with a tester to check the pressure. when he is there check for small leaks in the lines as well. It's tryng to work but no pressure to work wityh.
Feb 22, 2014 | Refrigerators
I have a Ropper Referigerator model # RT18bkxkoo. I am facing following issues: 1. The freezer section is working but I have noticed some ice developed at the back wall. 2. The referigerator section...
were
werw
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
dfg
Dec 27, 2010 | Roper Refrigerators
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Our kennmore side by side referigerator bought two years ago seems to have lot of ice in the freezer compartment. there is ice formed over the vents in the referigerator side and things (milk) is getting...
is the ice on the back wall or was the door left open?also send the model number,you'll find it in the fridge side on the right hand wall up near the ceiling,it will start with like 106. or similar
Sep 04, 2010 | Kenmore Refrigerators
Freezer cold; referigerator not
YOU HAVE A DEFROST PROBLEM., THERE IS A 95 PERCENT CHANCE YOU NEED DEFROST HEATERS. BUY THE PART HERE.
http://www.searspartsdirect.com/partsdirect/index.action
Apr 23, 2010 | Hotpoint HSS25GFP Side by Side...
What temp.should the ref. and freezer be
referigerator appx 36 degrees freezer -5 to -10
Sep 29, 2009 | Samsung RS2534 Side by Side Refrigerator
Ice is building up on the back cooling panal in frost free referi
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Refrigerators
Vegetable section too cold, freezing the vegetables
if youd like you can remove the affected crisper, locate the "adjustment slidelever" and remove it, behind there youll find a hole(which is what youve been restricting to lessen the cold air flow.) try wadding up a ball of perma-gum, window sealer, some sorta plug forthe hole, its not nessecary for function of refrig, only to make the crispers colder, but usually too cold. blocking of fthe hole willl make the crispers only as cold as rest of refrig
Mar 23, 2009 | KitchenAid KSCS25FKSS Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
260 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
