Question about Vtech Lands Phones
No dial tone,still ringing with incoming calls,display reading power failure and out of range
Sorry, this is not a solution, but I have the exact same problem! Did you ever figure it out??
Posted on Oct 07, 2010
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
Phone sees call, but can't pick-up. Can't get d-tone to call out?
Just a suggestion (without knowing what troubleshooting steps from your manual you may have taken): Remove the batteries from the back of the handset and then put them back in after a few moments. My Panasonic KX-TGA8231B (DECT6.0) phones were acting up just like your Uniden is. All functions returned after this power interrupt "reset" with the batteries was done. Hope that helps. Good luck. - - -Gerry
Nov 30, 2009 | Uniden TRU9485 Cordless Phone
Have setup in this order dsl modem,dir615 router,spa2102 phone adapter,get dial tone,hear ringing when making or receiving calls but no voice,what gives??
incoming voice ports are not open on the router. the devioce uses one IP port to set up the call (ringing) and at least 2 others for audio. read the manual I'm afraid.
Nov 06, 2009 | Computers & Internet
No dial tone - phone rings for incomming call but I can't hear or talk
This can be a problem with your handset.
Have you tried a different phone in that same jack?
Apr 17, 2009 | Lands Phones
Cannot get dial tone
try to make an incoming call to the phone in question by dialling the phone number from a mobile or whatever.if the phone does not ring then the line itself is not connected or has a wiring problem.
so if no dial tone and no incoming calls then check the line itself
Dec 20, 2008 | Lands Phones
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Unable to dial out, check voice mail and see call display
Hi at the back of the phone you will see a selectable Hi/Lo/Off switch. Slide the (Ringer) switch to High position or Low position to turn the ringer on. Hi for high volume Lo for low volume.
To prevent hearing any ringing of incoming calls slide the (ringer) switch to the off position but when you ready to accept incoming calls again remember to slide the switch back to either Hi or Low setting. Hope this made sense and helped.
Oct 24, 2007 | Curtis Trimline TID582 Corded Phone
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Lands Phones Logo
138 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
