Question about Whirlpool GEQ8858H Dryer
My clothes dryer fuse blew and has now been replaced. It melted the fuse holder but I was able to find a replacement part. The dryer now works but does not heat. I have been told the dryer heater may also have a fuse. Does it sound like the heating element has gone? How do I fix this?
  • 2 more comments
  • lahdidah1 Sep 10, 2010
    Thank you for your advice. I will try the thermal fuse first and let you know what happens.
  • lahdidah1 Sep 11, 2010
    which side is the heating element on? Is it the side with the black cover or the side with the silver cover?
    I'm a single woman trying to do this so appreciate the help.
    I went to an appliance part shop yesterday and the guy said it's probably not the thermal fuse and I should check the element. I've looked at the back of the dryer and don't know which cover to remove, the black one on the left side or the silver one on the right side. Can you advise please?
  • Whirlpool Master
  • 19,396 Answers
Hi.
the heating element is tested removing it from circuits and reading impedance at its terminals. If the element is bad, then circuit will be open (Ohms stay on infinity).
Rather than the heating element you should replace the thermostats kit. Thermostats are also tested reading Ohms. When a thermostat is good it must read zero or very low impedance at room temperature. The thermal fuse is tested in the same way, I do not know if you already replaced this part. Check the termal fuse first.
Here parts and diagrams:
One Time Use Thermal Fuse (part 7 in diagram)
CUTOFF-TML (Thermal Cut-Off Kit) (part 9)
High Limit Thermostat(part 15)
Cycling Thermostat (part 8)
Heating Element (part 17)
Here the diagram, click on picture to enlarge:
Posted on Sep 10, 2010
  • Ginko
    Ginko Sep 10, 2010
    If you want use a multimeter to test te termal fuse. Thanks for the update.
  • Ginko
    Ginko Sep 11, 2010
    Hi.
    About your question " which side is the heating element on? Is it the side with the black cover or the side with the silver cover?"
    If you are talking about the thermal fuse, this is in the heating group, above the element on the other side, not on top of the element. To help I suggest printing the diagram above and finding nr 7 (look at right top of picture)
    See also the hints here: Installation Instructions from users
I have a Panasonic inverter microwave. Was working perfectly an hour ago. Now totally dead. There is no light or anything. Have checked plug and fuses. No smell or anything. Can you please help.
Could be a shorted inverter blew fuse and unit dead. Or bad fuse holder got fuse hot and melted fuse so now unit dead. Must check fuse first and if bad replace and try, if it blows as soon as it tries to heat probably bad inverter. If it works for a long while then quits maybe bad fuse holder not grabbing fuse tightly making it over heat. So then bad by temperature not amperage.
Jun 20, 2017 | Panasonic Microwave Ovens
Clothes are melting in my dryer
Hello Thelma;
My name is Peter. I am a retired field service appliance technician.
Good for you changing the fuse. More and more women are becoming handy with repairs.
Unfortunately, the fuse blew because of another problem.
You may have a high temperature limit switch problem. You may have a time cycle problem.
This is a hard question to answer since you did not provide a model number for me to see what dryer you have.
Please submit your question with the model number. Open the dryer door the model number is on a label inside the door.
Nov 30, 2014 | Kenmore Dryers
DRYER GETTING HOT---CLOTHES TOO HOT TO HANDLE----BLEW THE THERMAL FUSE---REPLACED THAT AND THE CYCLING THERMOSTAT------WENT THREW THE CYCLE---THEN THE WIFE ADDED SOME MORE TIME AND IT SHUT DOWN IN ABOUT 5...
Sounds like your vent is stopped up . Pull the dryer out from the wall and disconnect the 4" vent. Look into it and see if it is stopped up with lint. If so clean it out good. Also, make sure the hose isn't pinched.
May 14, 2011 | Dryers
I have a Kenmore 110 Clothes Dryer. I live in an old house and it has fuses instead of breakers. The other day a fuse blew and the dryer stopped as did a television and a space heater. I replaced the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg YOu may also need to check the fuse block again it takes two fuses to run the dryer
Feb 10, 2011 | Kenmore 63942 Dryer
Kenmore 90 Series electric clothes dryer thermostat fuse had no continuity. Replaced the two fuses the parts place sold us. Turned it on after repairing, did heat up but then blew out the same thermostat...
I would say a venting issue, here is a thread, hope it helps Tim:
http://forum.appliancepartspros.com/dryer-repair/19493-dryer-blowing-thermal-fuses.html
Dec 23, 2010 | Kenmore 659 Electric Dryer
Dryer not working
check to see if your vents are clogged its the num. 1 reason. if they are most likely your thermal fuse blew out, have it replaced. Another reason is your heating element went bad. Check for continuity on both items.
Apr 16, 2010 | Whirlpool LER4634J Electric Dryer
Kenmore electric dryer Mod. 100.66662501, type dwjr-ele-2406028-fm54 Dryer blew fuses, so we replaced the fuses. Dryer then ran about 10 minute, was heating fine but then blew the fuses again. Help!
Assuming that the fuses you speak of are the external pair, and not the internal motor or timer resets:
Check the fuse holder for corrosion on the plates. Often the fuse is not properly seated because of this build-up and therefore has an intermittent connection. This will cause the fuse to either heat up, or overload; ultimately failing.
To remedy this, turn OFF the breaker, or main switch if necessary, and fix a wooden dowel with a piece of emery cloth (or sand paper) on the end. Remove any visible black corrosion from the contact plates.
Finish with a spray of WD40 to protect the plates and fuse end.
Replace the fuse, ensuring that it's tight, reinstate power and try again.
Was this  helpful?
May 13, 2009 | Kenmore Dryers
Whirlpool Duet Dryer
My dryer did the same thing, all the lights worked on front, but the bulb was out inside. All I had to do was to replace the thermal fuse and replace the bulb if you want light. The bulb don't have to work in order to dry clothes
Jan 03, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
