Question about Maytag MSD2756G Side by Side Refrigerator
My wife cleaned our Maytag refrigerator (MZD2666KEW) the other day. She started it up with the same temperature setting she had, but everything in the refigerator compartment froze. Now its on the lowest thermostat settings and seems to be working ok, but I'm concerned because we have no downside adjustment available. What could be the problem?
  • jensen_gary Sep 13, 2010
    At the suggestion of a computer engineer friend of mine, I unpluged the refrigerator of a few minutes and then pluged it in again. It is now working as it did before. Could the solution have been that simple.
  • 2,299 Answers
There is a rod like thermometer. You might check it and make sure that it is clear. Take a damp rag and clean it again. It could have cleaning solution.
Posted on Sep 13, 2010
  • 944 Answers
Cold air flows from freezer to the refrigerator section.
*)First Check the back wall or floor of the freezer section for frost.
Temperature control board can be defective:
The Freezer(evaporator) fan runs and circulates the freezer air to the refrigerator section.This fan is controlled by the Temperature control board.This fan should should stop after some time.It should not fully run.It will run when the defrost timer is active.
and check the damper is opening and closing through here only the air flows from freezer to refrigerator
*)Defrost timer is embedded on the temperature control board.So test the board and check it is defective.The defrost timer activates the thermostat, that is to warm the refrigerator.If it is defective it will not send the pulse.
*)Heater and defrost thermostat is located behind the back wall of the freezer section.This only controls the Heat.After the Defrost timer stops it makes the system warm.Defrost thermostat could be defective so test it.
*)Take the back cover off in the freezer and see if the ice is packed because of this the defroster is not getting the signal to defrost,Temperature control board defective.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 10, 2010
Our Maytag refrigerator gradually began cooling and freezing less effectively, so we completely defrosted it, wiped it dry and restarted it. The refrigerator worked great for about 10 days and now has
If the fridge can't keep the temperature, and you hear the motor running all the time, I'm afraid it lost its cooling fluid. (used to be Freon, but not anymore the use other fluids now).
When it is running most of the time, and you can't find a leakage, call a tech. Or if the fridge is old, start saving for a new one?
Sep 29, 2014 | Maytag Refrigerators
Maytag MFI2569VEM chills to the point that everything in the refrigerator section will freeze, regardless of the temperature setting on the front panel.
these tipe of units have an electronic board that controls basicly everything thats your problem you need to replace the electronic board. some times a temperature sensor wired to the elect. board fails but most of the time the board is the problem
Feb 10, 2014 | Maytag Refrigerators
Electrolux ESM6600SA Side by Side Refrigerator getting too cold after a clean
Hello John Wood - From what you have describes it sounds like the damper door might be open causing the temperature to be too cold. Use a mirror to look at damper door at the rear of compartment and use a hair dryer on damper door to deice for 5 to 10 minutes. Allow 24 hours and if the temperature is still too cold, then I would have a professional look at the damper door for replacement.
Oct 05, 2012 | Electrolux Refrigerators
Fridge and freezer warm. Mildly cooler air is coming out but the settings are on 7 for both fridge and freezer which are the coldest. Hard to tell if its actually cooler air or just seems that way because...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Maytag MFD2560HES Bottom Freezer French...
My refrigerator simply stopped cooling all of a sudden. It has been slowly getting warmer over the course of... 2-3 days, and this morning it stopped cooling all together. The power is on, the temperature...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 25, 2010 | Maytag PTB1953G Top Freezer Refrigerator
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Maytg Top Mount Freezer drip tube leaks into bottom of Refrigerat
Just had this problem a few weeks ago. tube from freezer was frozen solid 1-2 feet down from the freezer. Empty EVERYTHING out of the the Fridge and the freezer into coolers or other suitable 2-4hr container(s). Unplug the unit and use a hair blow dryer on the coolest warm setting. If it's too hot it may melt plastic or styrofoam parts. As long as long as you have everything out and it's going to be at room temperature for a while, why not clean it totally out with fantastic or your favorite cleaner. Once your sure the clog is gone from the tube, put it all back together, plug it in and stop being a slob and keep it clean!!!! hehehehehehe
Sep 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer will not get cold
Hi..
You need to check this following:
  • Check the temperature setting
  • Make certain there is a three inch space outside of the refrigerator between the walls and the back and sides and at least a one inch gap above, to allow for air flow
  • Clean the condensor coils
  • Unplug the refrigerator, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
Good luck !!!
Regards
PCmania
Jul 10, 2009 | GE GSS25LGM Side by Side Refrigerator
fridge has timer to adjust for defrosting, but the not working working you to manual defrost the unit to avoid ice formation inside the fridge.
Dec 30, 2007 | Turbo Air 49 cu. ft. / 1388 liter...
Maytag MSD2756G Side by Side Refrigerator Logo
76 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
