Question about Freeplay Energy S360 AM/FM/SW/DAB Radio
Have undone the screws of the Freeplay 360, but unable to remove the back, why ?
Remove the other screw behind the black lable then you will be able to undo the back cover
Posted on Nov 26, 2010
I have undone three bolts connecting rear tail lights to fender on bonnie t100 2006 but am unable to remove tail lights . driving me crazy
some manufacturers use a sticky tape/silastic to seal the area around the assembly where it goes into the fender as well as mounting bolts to hold it in position
check for a 4th screw where it would be hard to fit a socket
Feb 07, 2016 | Cars & Trucks
How to adjust the clutch on a 2003 sportster 883 custom
Slide the rubber cover off the cable adjuster. Then holding cable adjuster with 1/2 inch wrench, loosen the jam
nut using a 9/16 inch wrench and back the jam nut away from the cable adjuster and then move the adjuster toward jam nut to introduce a large amount of free play at hand lever. THEN remove the locknut and bolt to free the left side footrest from the footrest support and then remove the footrest and spring washer and THEN using a T-27 TORX driver, remove the four TORX screws with washers to remove clutch inspection cover exercising caution to avoid damaging or dislodging the quad ring in the primary cover. THEN slide the spring with the attached hex lockplate from the flats of the adjusting screw. THEN turn the adjusting screw counterclockwise until resistance is felt THEN back off the adjusting screw 1/4 turn. THEN slide spring with hex lockplate onto the flats of the adjusting screw and if necessary, turn adjusting screw clockwise just slightly so that the lockplate slides onto the flats while also fitting within recess of the outer ramp. Replace the quad ring if it is very old, deteriorated or etc. and verify that quad ring is fully seated in the groove of the primary cover and a few well spaced drops of instant contact cement can be used to hold it in place. Using the T-27 TORX driver, install the TORX screws and washers to secure the clutch inspection cover in place and tighten the screws in a crosswise pattern to 84-108 in-lbs (9-12
Nm). THEN turn the cable adjuster clockwise away from the jam nut until all of the slack is eliminated. THEN pull the clutch cable ferrule at the hand control end of the clutch cable at the hand control lever bracket away from the clutch hand lever bracket to check the free play. You need to obtain 1/16 to 1/8 inch free play between the end of the cable ferrule and the clutch hand lever bracket i.e. while you are pulling the cable away from the clutch lever mechanism bracket there should be a space or freeplay of 1/16 to 1/8 inch or in other words if you can pull the clutch cable away from the clutch lever bracket that much you have the correct lever freeplay, so turn the cable adjuster as necessary to get this amount of freeplay between the end of the clutch cable and the clutch lever bracket on the handlebars. After you have adjusted the cable so that you have this freeplay then hold the adjuster with a 1/2 inch wrench and using a 9/16 inch wrench, tighten jam nut against cable adjuster and then pull the rubber cable adjuster cover over the cable adjuster mechanism. THEN place the spring washer over the lower inside hole of the left footrest support with the concave side of the spring washer facing the support flange. THEN align the holes in the footrest with the threaded holes in the support and spring washer and install the bolt and locknut and tighten the locknut to 96-192 in-lbs (11-22 Nm).
Aug 06, 2014 | Motorcycles
Tv stand screws spinning, unable to remove stand
Sounds like you stripped the threads out or the nuts molded in came undone.
Try to get a hold with a needle nose pliers of the head and at same time back the bolts out---a screwdriver wedged just under the head and pulling up may work as you back the screw out--lever it gently---careful as excessive force down can damage the screen which is fatal.
May 26, 2012 | Philips Televison & Video
Set clutch free travel
To set the clutch free play, you need to do the entire clutch adjustment or things just don't work correctly.
Follow the clutch cable about halfway down and you'll find a rubber bellows type cover that protects the clutch cable adjuster. Move this cover up or down, loosen the locknut, and adjust the adjuster inwards to gain a good deal of slack in the cable.
Now, remove the primary cover. In the center of the clutch, loosen the lock nut. Now turn the adjuster inwards JUST UNTIL YOU FEEL A RESISTANCE. DO NOT FORCE THE SCREW. If you need to, back the screw out and then go back inward until you feel the resistance. Once you feel the resistance, back the screw back outward 1/2 turn. Lock the locknut and replace the derby cover.
Now, go back to the clutch cable adjuster and adjuster the adjuster outwards until you have 1/8" freeplay. Work the clutch several time and recheck the freeplay. When finished, lock the locknut and replace the bellows type cover.
Good Luck
Steve
Dec 25, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
I have 2 stripped heat sink screws I need to remove any suggestions?
Hi, what do you mean by 2 stripped screws do you mean the pins the x clamps fit onto or have you removed the xclamps and used normal m5 machine screws,
if its the xclamp pins then use pliers or mole grips
if its the m5 machine screws then you have 2 options either get a decent set of mole grips and lock these onto the head of the screw and these should then get it undone or you will have to drill them out using a tap and die set.
let me know what screws are threaded, mole grips should do it as these clamp on
Dec 04, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
How do i adjust clutch properly on 2003 sporty
To adjust your clutch on your Sporty, find the cable adjuster in the middle of the clutch cable. Move the cover out of the way, break the locknut loose, and adjust the adjuster inwards to get as much freeplay in the cable as possible.
Now, remove the cover from the clutch release mechanism on the primary cover. Remove the spring and the locknut. Inside you'll see a slotted adjuster screw. Turn the adjuster counterclockwise as far as it will go. Then back up clockwise 1/2 turn. Reinstall the locknut and the spring, then the cover.
Go back to the cable adjuster in the cable and adjust the adjuster outwards until you get about a 1/8" freeplay in the clutch cable. Work the clutch several times and check the freeplay. If correct. lock the locknut and replace the protective boot.
Good Luck
Steve
Nov 20, 2010 | 2003 Harley Davidson FXST Softail Standard
How do i get the proper clutch ajustment on a 1989 xlh 1200 sportsters.i have the slack out of the cable and all the play out of the clutch ajustment screw.now what do i do next?
Ok, let's start back over again. To properly adjust the clutch, you MUST do it in a particular method due to the design of the release mechanism.
First, you must "unadjust" the cable. Find the cable adjuster and "unadjust" it making the cable as short as possible, lots of freeplay in the cable.
Then, remove the clutch access cover and remove the spring and the "lockplate" that looks like a nut with a stem on it.
Turn the clutch adjusting screw counterclockwise to remove all the free play.
Now, back off on the screw 1/4 turn.
Then reinstall the "lockplate". if it doesn't want to go back in, you may have to rotate the adjusting screw clockwise just enough to get it back in. Put the spring back in and put the clutch access cover back on.
Readjust the cable so that you have a freeplay at the clutch lever of about a eighth (1/8") inch freeplay or about the thickness of a nickle.
Lock everything down and this should be correct.
I have found that sometimes you have to "tweak" the cable adjustment to get a clutch to engage exactly where a particular rider wants it to start engaging. This is a preference type thing and has to be done on a "trial and error" basis with the cable adjustment. But, you must use this method to adjust the clutch down at the engine end of the cable. Good Luck!
Dec 20, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
I am unable to remove the plate once undone screws to be able to add extra ram ( a further 1GB)
Acer bottom plastics can be a bear at times, but they will come off, they just need persuading. The screws don't come off the plastics because of a small nylon screw retainer, so have to make sure you have accounted for all the screws and that they are all backed off. Then look for the recessed area which is a pry area, use a flat hard plastic, wood tool and pry one side off and then the other.
Sep 12, 2009 | Acer Aspire 5315 Notebook
Brand new polaris 500 won't idle, but runs fine?
It is probably your throttle cable freeplay. If there is too much freeplay the enginge thinks the cable broke and tries to shut it down. Try taking away some of it. It is easily done by pulling back the rubber boot that covers the cable adjuster. I think it should have about 1/4" at the most of freeplay. It should say in the owners manual.
Jul 19, 2009 | Polaris ATV
Unable to remove the backplate off Neff oven
If there are no screws at the rear of the oven compartment that you can see to remove, then you will have remove the oven from the housing, and remove outer rear panel of oven to access the element.
Check the 4 fixings again, because on some ovens , they are not using coventional screws, they are are using what are called Torx screws, and you need a torx screwdriver or key to undo them.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Neff U1721 Double circotherm Electric Oven
Freeplay Energy S360 AM/FM/SW/DAB Radio Logo
266 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
