Question about HP OfficeJet Pro K8600 - - color - ink-jet - A3 Plus - 1200 dpi x 1200 dpi - up to 35 ppm
Table borders are not straight - lines uneven
I have a micsoft2010 and I have a straight line on the document I cannot delete it
-try this:
-Open the document and click on the Left upper margin
(it high light the whole page then Click on Bottom Border icon
and Click on "No Border" It should erase that line.
Then save it again.
Mai
Oct 09, 2013 | Natural Rubber Hand Brush For Removing Pet...
How to reset a samsung pl201?
.adslot-overlay {position: absolute; font-family: arial, sans-serif; background-color: rgba(0,0,0,0.65); border: 2px solid rgba(0,0,0,0.65); color: white !important; margin: 0; z-index: 2147483647; text-decoration: none; box-sizing: border-box; text-align: left;}.adslot-overlay-iframed {top: 0; left: 0; right: 0; bottom: 0;}.slotname {position: absolute; top: 0; left: 0; right: 0; font-size: 13px; font-weight: bold; padding: 3px 0 3px 6px; vertical-align: middle; background-color: rgba(0,0,0,0.45); text-overflow: ellipsis; white-space: nowrap; overflow: hidden;}.slotname span {text-align: left; text-decoration: none; text-transform: capitalize;}.revenue {position: absolute; bottom: 0; left: 0; right: 0; font-size: 11px; padding: 3px 0 3px 6px; vertial-align: middle; text-align: left; background-color: rgba(0,0,0,0.45); font-weight: bold; text-overflow: ellipsis; overflow: hidden; white-space: nowrap;}.revenue .name {color: #ccc;}.revenue .horizontal .metric {display: inline-block; padding-right: 1.5em;}.revenue .horizontal .name {padding-right: 0.5em;}.revenue .vertical .metric {display: block; line-height: 1.5em; margin-bottom: 0.5em;}.revenue .vertical .name, .revenue .vertical .value {display: block;}.revenue .square .metric, .revenue .button .metric {display: table-row;}.revenue .square .metric {line-height: 1.5em;}.revenue .square .name, .revenue .square .value, .revenue .button .value {display: table-cell;}.revenue .square .name {padding-right: 1.5em;}.revenue .button .name {display: block; margin-right: 0.5em; width: 1em; overflow: hidden; text-overflow: clip;}.revenue .button .name:first-letter {margin-right: 1.5em;}a.adslot-overlay:hover {border: 2px solid rgba(58,106,173,0.9);}a.adslot-overlay:hover .slotname {border-bottom: 1px solid rgba(81,132,210,0.9); background-color: rgba(58,106,173,0.9);}a.adslot-overlay:hover .revenue {border-top: 1px solid rgba(81,132,210,0.9); background-color: rgba(58,106,173,0.9);}div.adslot-overlay:hover {cursor: not-allowed; border: 2px solid rgba(64,64,64,0.9);}div.adslot-overlay:hover .slotname {border-bottom: 1px solid rgba(128,128,128,0.9); background-color: rgba(64,64,64,0.9);}div.adslot-overlay:hover .revenue {border-top: 1px solid rgba(128,128,128,0.9); background-color: rgba(64,64,64,0.9);}6_4_2012_11_48_48_am.jpgTurn The inner bit towards you until it goes in fully then turn it on and it might work. Thats what I did and it worked
Feb 12, 2012 | Office Equipment & Supplies
I have changed my XP for a Windows 7 with Office 2010. I cannot find the facility in Word 2010 to draw lines between text, erasor, etc. (which I find very useful when constructing Family Trees.) Is there...
Almost all the features of Older versions of MS Office are available in Office 2007 & 2010.
If you are working with tables, and wish to add/ draw lines using pen and use eraser, then after drawing the table, click the drop down and select 'Draw Table' and the table borders editing options will be displayed after clicking the table (the pen and eraser). The picture below shows the steps:
Hope it helps! Good Luck!
CreativeTECH
Apr 12, 2011 | Computers & Internet
I have a hl 5140 printer and there are lines on the side of the page when it prints.
Hi
Hope I can solve your problem
The first thing is do you go to print preview before you print if you do and the line is there it might have something to do with your page border go to your page border and put on no border
It also might have something to do with not having your paper correctly in the printer make sure all your paper is the same in the printer and it is all straight
and correct at the time of print.
but my bet is that you have your page border on 1 side of your paperwhen you are doing a document up the top you have page borders make sure it is on no page border
I hope I helped
Jan 22, 2010 | Brother HL 5140 Laser Printer
Canon MP510 prints uneven lines.
I assume that you've cleaned the nozzles and alignment utility.  Try wiping the carriage bar with a lint free cloth dampened with rubbing alcohol. Also, the paper feed rollers may have collected some "goo" and should be cleaned with the rubbing alcohol. This should clear the problem.
Mar 15, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Some paper got stuck recently in the printer but it has now cleared, however everytime I print now the document comes out slightly misaligned and the sentences for example are not in a straight line , can...
Dear Winsor Family,
It sounds as though you still have a small peice of paper caught in the auto sheet feed assembly. This is the part just behind the carriage rail. This is not an issue that any body other than a canon technician can fix. It will most likely involve the stripping down of the unit and the consequent re aligning of the asf. this can only be done by a trained technician.
Gremlin 11
Dec 09, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Platter not spinning properly
Make sure the platter is seated correctly. Lift it off, and set it back down. Also check to see that there is no debris or foreign matter stuck underneath the platter or where the platter sits.
Check to make sure the platter itself is not bent or warped. Do this by removing the platter (lift up), and then put it on a flat table/surface. Look at it from the side. Is it warped?
Hope this helps
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Jul 24, 2008 | Vestax PDX-2000MKII PRO Turntable
Please Help
How did you put the border? Don't use "|".
Use table, or text box.
By the way, if you want to have several "|" in line vertically, do with "tab". Block the area, click in the ruler to make tab stop. Make sure you have chosen the left tab (see the sign in the corner top left).
Let me know if it is not clear enough
May 28, 2008 | Microsoft Office Computers & Internet
How can I get A4 size borderless prints
From what I can see, this printer can only do borderless prints onto 4x6" paper only. Larger print jobs such as your A4 will have a border.
artifixit
Dec 19, 2007 | HP PSC 1410v All-in-One Printer
HP OfficeJet Pro K8600 - - color - ink-jet - A3 Plus - 1200 dpi x 1200 dpi - up to 35 ppm  Logo
43 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
