Question about Ovens
I have a twin oven, CDA CD 9002/ss. I think that the bottom element is no longer working, but I can't access it to check. How do I access it please?
  • 25 Answers
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
Posted on Dec 12, 2007
  • 1462 Answers
SOURCE: ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Posted on Oct 01, 2008
burdfrenzy
  • 348 Answers
SOURCE: HAve an older model dacor oven model w305. bottom
I just found 3 on Ebay. put in search dacor element. You will need the part number or you can email them if it will fit yours. goodluck
Posted on Oct 16, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a NEB oven (.06) and need to check the
You do not access it from inside.
It is usually a case of removing a side panel to access the element, possibly the top cover as well.
Hope this helps you.
Posted on Dec 19, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a Whirlpool AKZ161/ix/03 double oven in
If it is fan assisted, and the fan is working o/k, then the chances are it is the element.
This is usually located at the rear of the oven compartment behind a removeable cover.
Normally a straightforward repair
MAKE SURE POWER IS OFF !!!!
Please rate my solution.
Thankyou.
Posted on Jan 27, 2010
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
My oven only heats up to 160 and has a code f8
Faulty ss relay. Top cc element or bottom ir element or missing phase on three phase system.
Sep 26, 2011 | TurboChef C3 Single Oven
How do I replace the bottom oven element in a CDA CD 907 double oven
ISOLATE MAINS POWER BEFORE WORKING ON THIS APPLIANCE
Remove the back of the oven check temp controller before replacing or buying element, as this can often stop any heat being produced. The element is in front of the fan, if this model is fan assisted, remove fan, after removing element inspect to see any small hole in metal, if you see a large hole more than 10mm , this could be a sign that the fan needs cleaning. Clean fan with WD40, do not switch oven on untill fan has dried off. Then replace element, switch oven on low with door open, if you feel slight heat, go for a full test, gradually build up heat, keep on for at least 30 mins, make sure the oven reaches temp, you can expect some smell from a new element, this is protective oil, and considered normal.
May 10, 2011 | Ovens
I have a NEB oven (.06) and need to check the bottom element to see if it's' working or not. Do you know how I can access this element as I can see no way to do so from inside the oven?
Dec 18, 2009 | Ovens
Fdp 231 tcp 21 The bottom oven the fan is working but the oven does not get warm
It is likely to be the oven element that is faulty, if the fan is working o/k, then replacing the element should solve the problem. it is located at the rear of the oven compartment, where the fan is.
if there is no visible sign of fixing scews in the oven for the element or cover, then you are going to have to access it from the outside rear panel of oven.
Please leave feedback.
Thanks.
Dec 14, 2009 | Candy Ovens
Ovens Logo
202 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
