Our lcd teac tv suddenly started flashing red, then blue, then green continuously. Turning it off etc doesn't help. This seems to be a common fault with many Tvs ( according to google search) but no one seems to know exactly what it is or how to fix it. Any ideas
SOURCE: Picture Flashing
I have a similar problem but my picture flashes black and white and the sound goes at the same. Also sometimes it will flash pink and blue. I've read elsewhere that the issue is a known problem with compatability between Samsung tv's and sky boxes. Apparently the box needs to be replaced but I'm unsure what type of box. I've read perhaps a PACE sky box could fix the problem. I think the best option would be to contact Samsung - that's what I'm going to do.
Posted on Apr 01, 2008
Coldcut
  • 1554 Answers
SOURCE: LG 42KK Power Supply Schematic Requested
you won't find any just ,
use a thermal probe or thermal gun as heat is likely the issue ,
if nothing else replace the main diode /rectifier and caps.
I find that if I replace the hottest items that usually the fix
if there is room for a small fan you will be doing them a great service and extend the life of the tv.
you may find some info on the power supply from one of these links they are generic enough
http://www.pacificdisplay.com/links.htm
Posted on Jun 10, 2008
SOURCE: lcd not turning on
May i know is it the power led light blinking or just steady?
Posted on Jul 21, 2008
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
SOURCE: When I plug in my SOYO MT-SYTPT3227AB LCD TV it
If you want to know how I did it send me $9.95
Posted on Jun 29, 2009
How do I fix Samsung ue40h5030ak led tv that the screen is flashing red green blue white
LCD panel fault. If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 26, 2016 | Samsung Televison & Video
Sanyo 37 LCD ce37ld33-b
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Sanyo Televison & Video
Acoustic solutions tv screen flashing coulour blue red and green what is the problem and how to solve me help please i need help
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
These flashes are fault indications, called blinking codes.
May 22, 2014 | iLO 3200 32 in. LCD Television
RED GREEN AND BLUE
hi sound like epprom fault there's a memory chip installed on the main board of the tv sometimes these can cause this fault hope i'm wrong good luck
regards
shaun
Jan 25, 2014 | Emerson LD195EMX 19-inch LCD HDTV/ DVD...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
We cannot get our hdb841 to tune into our awa hd
Hi! I believe you have some concern on how to get good picture on your hd tv. I will be more than glad to assist u.. on your teac hdb841- there is a port connection - ant in, you have to connect the ant cable from your off the air tv antena to the ANT IN of the Teac HDB841. then on the back of your Teac HDB841, you have several output connection there like component, coax, s-video, rca and hdmi. since u have the hdtv u need to use the hdmi or the component cable whiich is the red blue and green then access the menu of the teac hdb841 and do a scan for the local channels.. ur tv should tune in to hdmi if u use hdmi cable or component if u use the red blue and green.. i hope this will fix the problem..
Aug 24, 2009 | Televison & Video
Xerox XL592DS Flashing Colors, Nothing on Screen
Sorry time for a new monitor you might open it up and look at the capacitors and see if any need to be replaced the bad ones will be domed on top normal is completely flat
Jun 19, 2008 | Xerox XL592DS (Silver) 19 in. Flat Panel...
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
