Copier was in the process of photocopying when suddenly power went off . Power switch was opened and when the machine was switched on again after powere was restored, it tried to boot but failed and showed E000000-0000
  • 113 Answers
Go to the service mode and reset the machine
Posted on Sep 10, 2010
Konica bizhub 283 photocopier error code c9401
FIRST, if this code comes back. Have a technician look at it the exposure lamp the bright light under the glass is bad or the board controlling it.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 22, 2017 | Konica Minolta Konica Bizhub 283 Copier,...
How to shutdown photocopy ir3025
The proper way to shutdown the machine is to press and hold the Power button in Control Panel for 3 seconds and wait for the shutdown instruction displayed. And turn off the main power switch located at the lower right side portion of the machine.
Jan 09, 2014 | Canon ImageRunner 3025 Black and White...
I am Thomas from South Sudan my Kyocera Photocopier 1635 Series error code : C6000.What to do sir?
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
Jan 20, 2013 | Kyocera Copystar CS-1635 Copier
Error code E000 on canon photocopier means
the thermal switch is open. you need to check this part first and if it's open you have to replace it and then erase the E code in service mode-function-error-ok.
Apr 15, 2012 | Canon NP 6050 Copier
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
Our copier IR 5000 sudden die. any suggestion ?
Die as in no power? check breaker on back of machine it is resetable. Switch off then on, then switch main power switch on right rear on again to check.
Apr 19, 2010 | Canon ImageClass MF6540 Copier
Error SC541 ON NRG MP 1600L
First try entering into SP mode by pressing:
Clear button>1 0 7> and press and hold the Stop button for 3 secs. Then switch off and on the copier.
If SC 541 code is still there, check the following in the fuser unit:
  • Fusing thermistors defective or out of position
  • Thermostats open circuit
  • Power supply board defective
  • Loose connectors of Fuser unit.
Good luck and please rate me, thanks.
Feb 26, 2009 | Gestetner DSm615 Digital Imaging System
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Error CH uppon power up...copy lamp comes on scaner moves forward 2...3 inches shakes and machine stops...
OK, CH normally means the one of the covers(front or side panels) is open or the developer unit is unplugged try these to see if that fixes the problem. p.s When the covers are closed a small tab on the covers triger a interlock switch or optical switch. Hope this helps
Aug 22, 2007 | Sharp AR-160 Copier
No power
Try it in another powerpoint. Try uninstalling it and reinstalling it on pc if not a stand alone unit. Could be the power support has died and may need repalacing.
Aug 16, 2007 | Dell 1600n All-In-One Laser Printer
88 people viewed this question
k24674
jasbo
jasbo
