Unable to access Styles Menu on PMDG 737NG FS2004 Screen blacks out and have to use Escape to recover it.
  • dfcmackenzie Sep 10, 2010
    Sorry. Don't think it is that ,as every thing else functions OK on the computer
    Might be the Windows 7 64bit, but *** I say every thing else works perfectly?
  • 3,083 Answers
I'm wondering if a reinstallation would help cure this problem. It sounds like a software "glitch", but couldn't find any reference to other people having this problem. If you google the number, you will get some forums and possibly be able to pose your question and get an answer from someone who's had this problem- that's all I can think of, in addition to a reinstall. Here's a link to the google search page:
http://www.google.com/#sclient=psy&hl=en&q=PMDG+737NG+FS2004&aq=f&aqi=&aql=&oq=&gs_rfai=&pbx=1&fp=652e0df67dbfff88
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 10, 2010
    Genius:
  • 1,478 Answers
It is possible that the operating system on your device is corrupt and will need to be reinstall, i will advice you repair the operating system on the system. see if this fix the problem.
Take care.
I have a Compaq Presario cq62 and when I turn it on it goes to the main screen press Escape it says down at the bottom to get to the startup menu but after that it goes to a black screen what do i do I can...
You are in the BIOS, which is the computer settings area. If you are unable to have it start up without hitting any keys then you either have a failing hard drive or a corrupt windows.
Dec 25, 2014 | Computers & Internet
Blank screen when accessing setting
Did you try leaving in unplugged for at least 10 minutes?
Dec 25, 2007 | Nintendo Wii Console
My 8gb usb is lighting but cannot be access
Initially, I thought my USB drive is not properly connected and because of that unable to access data. But, the problem is even after proper insertion of USB drive unable to access data. To overcome such issues, use Remo Recover tool to recover data from corrupt USB drive.
Mar 11, 2014 | Electronics - Others
My friend gave me an HP G60 and told me that you can log in but it just shows a black screen. After I log in, the whole screen is black, not off, just black with the cursor in the middle. It happens even...
Your friend probably tried to replace 3 .dll files so that you can use custom themes for whatever OS is installed on the computer. The only way to fix this is to recover the computer and restore to factory settings.
When you boot the computer hit escape to access the boot menu. See if there is a recovery manager option, and in there, a restore to factory settings option. (Also, hitting F11 works). If you have no option like this (this is essentially booting without a disk) you'll need a copy of your system restore disks that came with the computer.
Jan 17, 2011 | HP G60-120US Laptop
Hello, I had recently tried to restore my hp laptop to factory settings, I had pressed F11 and followed the set instructions, ,but recovery manger said it cannot recover from recovery dvd so i tried...
go to the start menu and key on the program lower tab. The go to accessories. Click on command prompt which takes you to the DOS screen.
Now you will see a blinking cursor on the black screen which all you need to do is to type in chkdsk /f /r
This will repair any programs that were not running correctly. after it is done your computer may reboot itself. If not reboot it and see what it does, Itshould work fine unless deeper problems in the EXE BATCH FILE is present
Jun 20, 2010 | Computers & Internet
When you turn on the TV the screen flashes through a sequence of red, green, blue, white & black screens. Unable to access menu & no sound. TV Model LG 27LC2D
Sounds like it's in a service burn-in mode. LGs need a service remote to de-activate. Probably easy for a local LG shop.
May 03, 2010 | LG 37LC2D Television
Unable to access windows or internet. Screen dark.
Take the battery out. Then run it through some tests. Plug it in without the battery and boot it up. Then unplug it, but the battery back in, unplug it from the computer and see if it will boot up with just the battery. Finally, plug everything back in, with the battery, and boot up. That should clear it.
Dec 31, 2008 | Toshiba Satellite A135-S4527 Notebook
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Dec 29, 2007 | RCA 27F634T TV
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
