Question about Dell 2135cn All-In-One Laser Printer
LOSING IP ADDRESS ON DELL 1235CN PRINTER - Dell 2135cn All-In-One Laser Printer
  • 49 Answers
SOURCE: Set up Dell 3010cn as network printer
Have you set it up on the network already or is this the first time? If you have set it up, you can access the network interface by inputting the printers IP address in your internet browser address bar.
If you are unsure of the current IP (assuming it's connected) try print a settings page. It should be on there.
Posted on Feb 27, 2009
  • 10 Answers
SOURCE: Need IP address for Dell 5100cn printer
You will need to print off a printer settings page. Usually found under the Reports menu or something similar. It will list the IP address. Once you have the IP Address, make sure it is set correctly in your printer drivers in the Control Panel on your computer.
Posted on May 29, 2009
kakee
  • 1269 Answers
SOURCE: dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Posted on Jul 16, 2009
  • 93 Answers
SOURCE: there is a dell wireless printer adapter 3300
Try installing the printer on all computers
Posted on Apr 13, 2011
Acadiemedia
  • 131 Answers
SOURCE: want to reset assigned Ip
When the Ready/Data light ready_light_icon_0.jpg is solid, press the Continue button continue_button_0.jpg to print a menu settings page and a network setup page.
Select TCP/IP heading on the network setup page.
There you can change your IP address.
Posted on Aug 10, 2011
How much does it cost to replace the imaging unit in my 1235cn laser printer?
Janice,
You can call the Dell Spare Parts Department at 1-877-717-3355 for pricing on replacing the imaging unit.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
DellCares
Dec 02, 2014 | Dell K159M 1235cn Multifunction Color...
I have just purchased a Dell laptop with Windows 7 home premium installed. I have a Cannon PIXMA MP495 printer, what do I need to do to operate thist printer wirelessly?
If you have a wireless router with a wireless network then -
Configure the IP address your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but at a higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 28, 2012 | Dell Computers & Internet
Dell 1235cn scanner locked
in shoul be scanner motor error.first see the scan light is blinking or not then open the scan lid and manualy rotate the scanner motor.if it rotate normaly then place it again and try to retest.if the problem not solved then replace the scanner mottor
Jun 17, 2012 | Dell Multifunction Colour Laser (1235cn)...
When networking, I can see the printer on the network, but when I send a test page, the printer immediately says "cancelling". I cannot figure what the problem is. Any suggestions?
There must be IP address conflict.
Check the Dell printer IP address
Open Printers and Faxes Folder
Right click on printer icon ( dell )
Click on Properties
Under Ports Tab check the IP address with check mark
If the Ports IP address is Different as that in Dell Printer
Highlight the Port with IP address and click on Configure IP below
Change the IP address to the Printer and Click OK
Also check if there are print job stuck in the Queue ( like no. 1,2 )
The printer icon should show READY and 0
Or Else, Right click on the printer icon and Click Cancel Print job.
Restart your PC and Printer and try to print. It should work
If this does not work, let me know what is the Operating system of your PC
Try this Step if your Operating system is Windows 7
Left click on Troubleshoot
Continue with the Wizard and complete it
You are ready to print.
Nov 02, 2010 | Dell 3000cn Laser Printer
1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
May 06, 2010 | Dell 1720dn Laser Printer
Dell 5100cn change ip address
Jul 16, 2009 | Dell 5100cn Laser Printer
May 26, 2009 | Dell 5100cn Laser Printer
Our wireless printer loses communication with pc
You are losing contact because you are losing your IP address for the printer. Do this:
Click on start>run>type in "cmd">then go to c:> prompt by typing cd\. Type ipconfig /release then type ipconfig /renew. This will re-establish your IP address for the printer and will not change for 24 hours. If you lose your contact after 24 hours then you need to contact your Internet Service Provider, tell them that your DHCP server is not renewing your IP address. There is nothing else that can be done on your part. The ISP provides the IP address.
Don't forget to rate this solution.
Jan 14, 2009 | Office Equipment & Supplies
Changing a Dell 3010cn IP address and Storecenter
Print a settings page from the printer. If you are not sure on how to get the settings page, download the user manual from support.dell.com, there should be instructions in there on how to get this. Once you have the settings page locate the IP address on the print out. Take this IP address (which may be different then the one you want to use) and open internet explorer, put the IP address in where you would normally type a web address, hit enter. This will take you to the embedded web server of the printer. Once you are there, you can look for printer settings, ip address or TCP/IP address. Once you have found this, you can set a static (meaning it will not change, unless you change it) IP address (the IP address your tech person gave you) and submit the information to the printer. The printer must be on and in the ready state for this to take hold. If you are prompted for a username and password for the embedded web server, dell default username in small case is admin, leave password blank or username admin, password is password. To confirm that the address has taken, print another settings page from the printer.
Nov 14, 2008 | Dell 5100cn Laser Printer
Dell 2135cn All-In-One Laser Printer Logo
198 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
