I went to play a recorded item from TV, pressed the play button and had the following message: assert(0) failed ! ../../stream/stream_pbacklayer/scr/stream-pback layer.c Line 6027 Inside pl_read_next_gop C) What does this mean? Can I reset the recorder?
  • 19,396 Answers
Hi.
The string is a C++ error message. To make it simpler think of it as a kind of Syntax error returned when the software cannot manage a variable.
Try first installing an updated codec pak. If that does not work, uninstall and reinstall back the software, then eventually reinstall codec pack.
If still no luck, use a different software. The problem is in any case caused by a software bug.
Here one of the forums on the topic.
Posted on Sep 10, 2010
How do I change the message on my magicjack phone?
From Your Computer
Step 1 Launch the MagicJack software on your computer.
Step 2 Press the "Vmail" button.
Step 3 Press "0" to personalize settings.
Step 4 Enter your password when prompted. The default password for MagicJack is "1234." Enter that password if this is your first time setting up voice mail.
Step 5 Press "0" to get your mailbox options.
Step 6 Press "1" to record a message that plays when you are unavailable, or press "2" to record a message when you're busy. The first message plays when your Internet connection is out, and the second plays when you're on another call.
Step 7 Press the "#" key to end the recording.
Step 8 Listen to the recording by pressing "1" again, and press "2" to accept the message or "3" to re-record your message. Repeat this process until you're happy with your message.
Dec 18, 2014 | magicJack Plus
How do I check voicemail for a Uniden DECT 6.0
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 03, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I access messages when I am not by the phone?
nschutz,
Remote Operation
You can operate your answering system from a remote location (when you are away from home, or from another room using a handset).
Use this function to check for recorded messages, to play or delete message. When using any touch-tone telephone, you can even record a new greeting message.
Remote Access away from Home
You can operate your answering system from a remote location using any touch-tone telephone.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code
3) The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
*For Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, enter the command again.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering system automatically returns to standby.
0 then 1 Repeat a Message
0 then 6 Answering System On
0 then 2 Play Incoming Messages
0 then 7 Memo Record/Stop*
0 then 3 Skip a Message
0 then 8 Greeting Message Record/Stop*
0 then 4 Delete a Message 0 then 9 Answering System Off
0 then 5 Stop Operation
1 then 0 Voice Prompts
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the number of messages stored in memory. You hear "To play incoming messages, press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system on. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Respectfully,
Adam04
Feb 28, 2011 | Uniden Cordless Phone EXAI985
I have a Uniden cordless answer machine,Can my meesages be retived?
You can operate your answering system from a remote location using any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even to record a new greeting message.
  1. Call your telephone number.
  2. During the greeting message, press 0 and enter your PIN code. By default, the pin code is "80" without the quotes.
  3. The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two. For help, press one zero".
Available commands are:
  • 0 then 1 Repeat a Message
  • 0 then 2 Playing Incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop*
  • 0 then 8 Greeting Message Record/Stop*
  • 0 then 9 Answer System Off
  • 1 then 0 Help Guidance
Jan 23, 2011 | Office Equipment & Supplies
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
I have a code for my Uniden cordless to get voice mail while away from home. Not sure what else I need beside the code.
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
handset). Additionally, you can turn on or off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any touchtone
telephone.
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
stored in memory. You hear "To play incoming messages, press zero-two. For
help, press one-zero." You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
* For the Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
5) After the command has finished, you hear intermittent beeps indicating that the
time from the chart above.
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Jul 09, 2009 | Uniden Cordless Telephone
Retrieving message
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
2) During the greeting message, press 0 and enter your PIN code.
Command Function
If you forgot to turn on answering system the directions for that are here:
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
Mar 18, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Picking up messages remotely
Try this...
Remote Operation
Command Function
Dec 12, 2008 | GE 25942GE2 Cordless Phone System
NTL VS205 lost manual
Lets see if I can get my hands on a manual. one moment
Jun 27, 2008 | NTL D6000 Cordless Phone
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
