Question about Sony Walkman NWZ-B142 MP3 Player
Only half the screen is displayed and the volume cannot be turned higher than 20 instead of 30!
  • 34 Answers
Half the screen - most likely is hardware/cable fault. no easy cure
volume - turn off AVLS in the setting
Posted on Oct 28, 2010
Half screen normal , other half blackened for 20-30 minutes, before turns normal. Recently getting longer to get normal screen and left side stays black(about 2" wide)
sounds like a bad smps or bad display. I would try the smps, but if that doesn't do it the display costs as much as the tv most likely.
Sep 07, 2013 | Samsung LN46A530 46 in. LCD HDTV
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
How do I set the clock on my Pioneer DEH-P6200 cd receiver?
With the vehicle on, turn OFF the radio. Next, Press the Volume and hold the VOLUME knob. You should see LANGUAGE on the display. Scroll the VOLUME knob until you see CLOCK SET. Pres the VOLUME knob and the HOUR will start flashing. Scroll the VOLUME knob to set the hour then Press it to set the Minutes. When you're finished. Turn off the radio, then turn it back on. When the radio is in use, the Radio Station will scroll on the display, then the Artist information, then after a few seconds (20-30), the Clock will display.
Jan 14, 2011 | Pioneer DEH-P6200 CD Player
I updated my video driver and now on 17 inch monitor display is coming instead of full monitor display how can i make the screen back to full 19inch display
Go to the Control Panel and click on Display, the the Settings tab. then change the screen resolution to 1024 X 768 or higher resolution.
The higher the resolution the smaller the Icons will be but you will be able to display more information on the screen.
Jun 09, 2010 | LG L192WS LCD Monitor
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
Jun 30, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Half screen lighter than other half
faulty display panel or faulty display driver
Aug 31, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Bose Wave System CD 2000 FM volume much lower cd stops if volume higher.
sounds like a loose cable from the control bard to , some one will have to open up to fix, i recommend bose do that for you,
as for fm volume, the same could be the cause as the fm antenna coudl be disconnected, ( are you using an external FM antenna ?)
Feb 29, 2008 | Bose Wave Radio
Displays "CUR"
You probably have too low of an impedance load on ot (too many speakers or wrong kind). It has to have a minimum of 2 ohms on each channel, or 4 ohms if bridged (that means don't put 2 subs on the bridge!!).
Sep 22, 2007 | Alpine MRV-F345 Car Audio Amplifier
Blue rectangle at bottom half of screen??
Try to change the Caption mode: Press ACTION to display the MAIN MENU Select TV - CAPTION - OFF It should help.
Sep 12, 2005 | Panasonic PV-M2058 20 in. Combo
Sony Walkman NWZ-B142  MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
