Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Took tray and grounds tray out to clean and it won't go back in - it is jamming. Have cleaned inside but still stuck. Tried pulling infuser out but this is stuck as well. Appears that central unit has moved and won't allow tray under now! Any ideas?
I had this problem last night. The infuser was stuck down too low and the tray wouldn't slide in. I got the solution from FIXYA, and it worked for me.
First make sure machine is off at power, then put just the coffee grounds collector and not the whole tray back into place, gently close the door, and then turn the machine back on. At first I couldn't close the door, but I fgured that the grounds collector was a bit too low, so just put something in there to hold it up while I shut the door. Turn the machine back on at power and HEY PRESTO, it all started up again, and then the infuser moved back into correct position.
Make sure you have a cup handy just incase water starts to rinse out.
Hope this helps
Tania
Posted on Oct 21, 2010
  • Stephen Johal
    Stephen Johal Apr 23, 2014
    This is the exact solution, thanks so much for posting this!!!! :)
  • Sharon
    Sharon Sep 12, 2014
    I agree, cannot thank you enough! Thrilled, just thrilled x
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
Message appears "Paper jam".
Paper jams can be true or false. A false paper jam occurs when the error message displays, but no jammed paper is in the product. The following solutions apply to both true and false paper jam errors.
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report
Solution one: Clear the paper jam Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray.
Step two: Clear the jam from the back of the All-in-One
  1. Figure 2: Remove the rear access doorc01562020.gif
  2. Gently pull any jammed paper out of the rollers inside the product.
  3. Carefully remove any scraps of paper that are still stuck in the product.
  4. Reattach the rear access door. Insert the two posts on the right side of the door into the holes on the product, and then push the door in until it snaps into place.
  5. Reconnect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
Step three: Clear the jam from the front of the All-in-One Follow these steps to remove the paper jam from the front of the product.
  1. Without opening the cartridge access door, check the tray for jammed paper that you cannot remove from the back.
  2. If you see jammed paper, gently pull it out.
Step four: Print a self-test report
  • If the issue persists , continue with the next solution.
Solution two: Make sure that the carriage can move freely Follow these steps to make sure that the carriage can move freely. Step one: Check the paper path
  1. Check for any paper or object that might be stopping the carriage. Figure 4: Example of paper stuck in cartridge access areac01950807.gif
  2. Remove any paper or objects you find.
  3. Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle , move the carriage to the right.
  4. Remove any paper or obstructions found.
  5. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left, and then to the righ
Step two: Print a self-test report
  • If the self-test report does not print , continue with the next solution.
Solution three: Clean the rollers and the rear access door Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Follow these steps to clean the paper feed rollers inside the product. Step one: Clean the rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Press in the tab on the left side of the rear access door, and then pull the door away from the product to remove it. Figure 6: Remove the rear access doorc01562020.gif
  4. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  5. Press the cloth against the rollers and rotate them upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup. Figure 7: Rotate the paper feed rollersc00212278.jpg
  6. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely.
  7. Clean the surface and the rollers of the rear access door the same way you cleaned the large rollers inside the product.
  8. Replace the rear access door. Insert the two posts on the right of the door into the holes on the product, and then push the door in until it snaps into place.
Solution four: Service the product
Aug 08, 2011 | HP PSC 1610 All-In-One InkJet Printer
Yesterday and today the machine did not come on as normal it said press next + change, nyesterday when I did that it said generic alarm, but then worked, today the generic alarm would not go off. the book...
I had the same problem with the infuser stuck at the top and the triangle light staying lit. I fixed it by unplugging it from the wall. I then removed the side panel and the back panel.
Facing the rear move the sprocket that the motor drives. The best way to start it (if it is stuck) is with a flat screen driver on the right side of the motor and push the sprocket towards the front. Once it starts you can either pull the belt from the other side or push it from the right side. It took 10 minutes to get the infuser to completely come down.
After that I pulled it out and cleaned everything. When I put everything back together the light stayed on and the machine would not respond. I did fix it by turning on the machine, pulled the power plug, and when I plugged it back in the system went through its cycle. Everything is fine now.
Jun 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I have a Jura impressa C5, and drip tray will not go back in with the grounds basket installed. Seems as thought the mechanism is jammed out of place. I have cleaned out the tray and vacuum cleaned the...
I have a Jura Impressa 27. The tray, for some odd reason, was not going back in. I simply tried it without the top part - that receives the grounds - and was finally able to get it in. I pulled it back out and found some grounds that had been dumped. It seems something was stuck that wouldn't allow it back in with the top part. Then after I was able to put both pieces back in without a problem.
Mar 26, 2011 | Jura Capresso IMPRESSA F60
Delonghi Magnifica door comes open after grind and just before brew?
try changing the defusser..... bsc appliances 07779933829 postal service too.
Feb 07, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Hi I have a delonghi magnifica expresso machine. We did a cleaning of it and took the infuser apart (the screen off and the curved part with the spring. The machine keeps dumping the grounds into the...
I donot see any error here. Can you reset the spring in the infuser once again. The process of cleaning that you have mentioned is correct or you can follow the steps mentioned bellow :
Please double check whether the cleaning was properly done. Whenever the machine tells you to clean it, which requires you to
- Mobile steam wand while
- opened the door
- the drip tray and trash along
- Dump Truck and clean all the drip tray and waste
- re-assembly
Thanks
Oct 23, 2010 | DeLonghi Coffee Makers & Espresso Machines
Can't remove infuser to clean it
Turning off the power with the button is not enough. Instead, to remove the infuser: unplug the machine, wait a few seconds, plug it in again and turn the machine on. Even though you are technically turning it on, the machine will sense it was not turned off in an ok way, so it will "properly" shut off (and unlock the infuser).
May 06, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Paper Jam
You need to try clearing the paper using a airblower if you do not have a air blower try with a vacuum cleaner, surely it cleans up. Unless until you remove the paper it shows the msg.
If you think you have no other option and you tried everything its better to call some service guy and get it done.
Regards
Oct 03, 2009 | Office Equipment & Supplies
The machine struggles to move grounds through after brewing. The tray seems to be locked in.
Your brew unit is probably dirty and needs cleaning. However, it won`t always help just running the cleaning program. Try to clean out all the used ground that is stuck inside the brew unit; use your fingers or a toothbrush maybe. Then run the cleaning program. It may be smart to run the program once or twice after this too, but you don`t have to use the tablet everytime.
It is the grounds blade that holds the used ground container so you can`t get it out. This means that the brew unit stops in a wrong position, and don`t get back to grinding position before timeout. If you shut down the machine for a few hours, it usually moves back during startup. But of course; this indicates that you need to clean up inside...
Jul 16, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Magnifico eam3200 series...centre piece jammed
I have a perfecta and found that the mechanism that translates the infused up and down was jammed. I unplugged it and removed the back panel - two phillips screws - then you will see the motor and cog belt -BE SURE UNPLUGGED - I then turned the motor shaft using my index finger against the cog belt and with the access door open I could see the infuser translate down to a park position. I took it through an entire cycle which actually retracted the infuser and actuated the coffee grind sweep arm - there is a horizontal feature that looks like a sideways 'L' that seems to be a reference for the park location - since when the top of the infuser was at this mark the infuser unit could be removed and the infuser was in the compact configuration as described in the user manual. I am getting a general alarm still and would like to know if anyone could point me to an electrical schematic and functional sequence block diagram.
Oct 16, 2007 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
1,205 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
