During window installation i intiate stage how can i set boot sequence.can you tell me a initiating step of window reinstallation in boot sequence
  • 487 Answers
Hi, by pressing the F8 key during initial boot, your will boot into bios. From here you can change your boot squence, just remember to save changes before finishing.
Posted on Sep 10, 2010
Cylinderhead torque settings
I'm not sure what engine you have in your 95 grand am SO I will give you both the 4cyl and 6cyl Specs. Also you didn't ask for the torque sequence. I will include that as well for both. 2.3 DOHC Quad 4cyl: Torque sequence---> front ' 7 3 1 5 9 ' of engine ' 8 6 2 4 10 ' Step 1: torque bolts 1 thru 6 (26 Ft/Lbs & 90 degree turn) Step 2: torque bolts 7 & 8 (15 Ft/Lbs & 90 degree turn) Step 3: torque bolts 9 & 10 (22 Ft/Lbs & 90 degree turn) Recheck final torque in sequence *** CAUTION *** This engine uses "Torque To Yield" (TTY) head bolts that means they permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed in order to obtain proper torque. 3.1 liter V6 Torque sequence--> ' 6 2 3 7 ' ' 5 1 4 8 ' Step 1: torque bolts in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION *** This particular engine uses "Torque To Yield" head bolts(TTY) (that means the bolts permanently stretch during the initial installation.) You MUST use NEW head bolts when replacing or reinstalling the cylinder head in order to obtain the proper torque.
If you need further help, reach me via phone at https://www.6ya.com/expert/tasa_06404e20147f8840
Aug 22, 2014 | 1995 Pontiac Grand Am
Head bolt sequence and torque values on a 1999 Chevy 3.1L engine
if the 8th number om your VIN is a "J" then this is the correct prossess 3.1LTorque sequence --------- ' 6 2 3 7 ' ' 5 1 4 8 ' --------- Step 1: torque in sequence to 37 Ft/Lbs Step 2: turn an additional 90 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.Always coat bolt threads with the proper sealant.
if the 8th number on your VIN is a "M" then this is the correct prossess 3.8LTorque sequence --------- ' 6 2 3 7 ' ' 5 1 4 8 ' --------- Step 1: torque in sequence to 37 Ft/Lbs Step 2: turn an additional 90 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.Always coat bolt threads with the proper sealant.
Oct 12, 2011 | 1999 Chevrolet Malibu
My tosshiba satellite A665-55186 wont go in to windows boot, what can i do??
Just like other computers, your Toshiba laptop may start failing to boot the operating system completely, or may fail to boot up at all. Boot problems are caused by virus infections and issues related to hardware and software. With the proper troubleshooting techniques, boot problems can be remedied to get the laptop into good working condition.
1. Perform initial hardware checks. Ensure that the laptop has enough battery life to boot up. Charge the laptop using its AC adapter and then try to boot the laptop again. If nothing happens, plug the AC adapter into another power outlet. If this does not help, check to see if external drives (flash drive, external hard drive, etc.) are connected into one of your USB ports. Unplug it from the laptop and press the laptop's power button. If the laptop powers on but fails to load the operating system, proceed to the next step.
2. Ensure that the hard disk is not disabled in the boot sequence in your BIOS. Otherwise, the laptop will fail to fully boot the operating system. Reboot the computer and press a key that will lead you to the BIOS page. Set your hard disk as your "first boot priority," or first in the "boot sequence." Note that the steps on loading the BIOS as well as navigating throughout the BIOS pages will depend on what brand of BIOS is installed in your laptop.
3. Choose boot to the "Last known good configuration" if you get an error page before the operating system boots up. If after choosing this option the computer reboots again, choose "Start Windows Normally," if this is in the list of options.
4. Consider repairing or reinstalling the operating system if the computer still fails to boot after the steps above. Repairing the operating system will retain your current data and settings. Reinstalling the operating system means reformatting or deleting all data in your computer and installing a fresh copy of the operating system.
I hope you find it very helpful. Best regards from fixya
Aug 15, 2011 | Toshiba Satellite A660 Series Notebook
New laptop C650, how to install OS ?
If you are installing Windows, you need the Windows installation CD and the product installation code.
Boot up the Toshiba with this installation CD in the DVD/CD drive and follow the on screen instructions.
After Windows is installed you need to install the Toshiba's devices.
You may need to download these Toshiba drivers using another computer.
These instructions are just the basic details.
If you need further instructions, please get back to me and tell me at what stage you are having troubles.
Sep 29, 2010 | Toshiba Computers & Internet
I have a loptop in compaq company and wimdows XP .but the windows are currpte .in this reson i do not formet window XP.so plz tell me what am i doing .......
Do you have any data in your Desktop or My Documents
if it is not their than better to format.
If it is their than repair the operating system by putting the OS CD
Sep 28, 2010 | Computers & Internet
I am doing a clean install of windows 7 on my Acer T180 and I need to set the boot sequence to cd-rom first. How do I view the present boot sequence and how do I change it to cd-rom first if necessary?
As soon as you power on your laptop, you want to start pressing F2, it depends on who made the motherboard if it is not F2 then the key to access your "system setup" will usually be displayed in one of the corners during POST This is the initial startup routine of any pc this is the screen you will see the ACER logo appear.
Once you are in there you will want to be careful of any changes you make, the command you are looking for is the (boot sequence) on most PC's the (+) (-) symbol is the way to toggle your choices after you have placed the cdrom first in the sequence then save and exit and on the next startup the pc should know to look to the cdrom to load the install disc. Let me know if you need more help
May 20, 2010 | Computers & Internet
Head bolt tourqe settings on a toyota cressida
Cylinder head bolt removal sequence
Removal sequence: Front 3 7 11 13 10 6 2 1 5 9 14 12 8 4
***CAUTION*** The above sequence must be followed during removal as to avoid warpage of the cylinder head unit
Reverse sequence to install, Step 1: Torque to 10 Ft/Lbs Step 2: Torque to 18 Ft/Lbs Step 3: Torque to 25 Ft/Lbs Step 4: Turn an additional 90 degrees Step 5: Turn an additional 90 degrees Step 6: Torque the 2 recessed 8mm bolts to 13 Ft/Lbs *** CAUTION *** engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper Torque
Don't forget to rate this answer, Good Luck
Apr 24, 2010 | 1992 Toyota Cressida
Laptop won't boot up.
You don't need dos prompt to format the HDD. You said you already tried to reinstall XP so I would assume you have a Windows XP boot disk. During the initial start up of the Windows XP installation from the CD you should be prompted with an option to format and/or re partition your hard drive.
Firstly however you should check in BIOS if you have an option under boot to "Try other boot devices" and if it is enabled plus make sure your HDD is set to the first position of boot order.
If you have any USB drivers plugged in disconnect them and try again.
If all this is to no avail your HDD or motherboard might be damaged. Try and replace the HDD see if that works.
Hope any of these help.
Jul 27, 2009 | HP LaserJet 1200n Printer
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Monitor works during boot-up but not in Windows
Did you install the ATI catalyst software?  You will have to check a box that says active monitor on your graphics console for the appropriate monitors.
srich
May 27, 2008 | Acer AL2216W LCD Monitor
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
