Question about Royal 15MX Shredder
My royal paper shredder is jammed. How do I unjam the shredder?
    Genius:
  • 1,218 Answers
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Posted on Oct 09, 2010
3 Suggested Answers
JayBlair
  • 328 Answers
SOURCE: UNJAM MY EMBASSY TS 60 SHREDDER
You have to remove the top cover. Look under the top and remove screws. Gently lift top and do not stress the connecting harness. carefully remove paper shreds. Unplug of course!!
Posted on Jul 22, 2009
  • 1218 Answers
SOURCE: paper shredder jammed
Yes....this is a consumer model....NO BIN/BAG FULL INDICATOR....to keep costs down, you will just have to try to get the bin out a little at a time and slowly reach-in and "fish out the shredded paper...once you have enough out the bin will come out...hopefully the backed up paper has not jammed the machine and blown the PCB inside.....if it has give Royal a call at 1-800-524-0799 for parts assistance.
Posted on Aug 31, 2010
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
How do I unjam it?
Sometimes the only effective way to unjam a shredder is to turn it upside down (with power disconnected) and pick out the jamming material bit by bit. It is a tedious, messy job.
Aug 12, 2015 | Techko SH1524CP Shredder
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
Our shredder motor is working but it will not go forward to shred. It will reverse. I've unjammed every visible paper jam but still nothing. HELP!
If it wont run forward but does run in reverse you may have lost the PCB inside.... contact Royal at 1-800-524-0799 for parts assistance and pricing.
Nov 29, 2010 | Royal CIA 12X Shredder
Is it possible to unjam this shredder. It was allowed to get too full and I started eating it's own shredding . I have pulled all of the paper out that I can - but it still won't go.
If you have cleared all jammed paper out of the unit but its dead and wont run then its likely you have blown the PCB inside...replacement parts you can get from Royal at 1-800-524-0799.
Oct 16, 2010 | Royal 10X Shredder
My shredder is jammed and I cnnot get unjammed
Hi. Go to the local hardware store and purchase a small pair of needle nosed pliers. Use these to pull the paper from the shredder a little at a time. Then in the future only shred up to 3 sheets at a time so it does not jam on u. J.
Aug 06, 2010 | Royal 160MX Shredder
I have a Royal 7X Shredder which has developed a problem recently. The motor appears to try and run when paper is inserted, but the blades will only cut a 1/4 inch. The paper will not feed down into the...
I would definately say that you ahve some sort of jam in the lower half of the unit. If this is not the case, and you can see through it from bottom side up, then you have a belt slipping. There are 'toothed' belts that drive these. Most people call them timing belts, if you can get a hold of one or make sure yours hasn't come loose, I would.
Jun 27, 2010 | Office Equipment & Supplies
Shredder jammed
For any jammed shredder..try the following.. pull backwards on the paper while you switch the machine into reverse. Try not to tear the paper as if there is nothing to hold onto then you can't help the motor.
If this dosn't work then you will have to take the top cover off(after unplugging of course.) and the try to force the paper backwards out of the machine by turnings the cutting blades or gears in the reverse direction.
Jun 04, 2010 | Royal 150MX Cross-Cut Shredder
Paper shredder jammed
May 01, 2010 | Royal 150MX Cross-Cut Shredder
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
Royal 15MX Shredder Logo
923 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
