Question about Acer NSK8458AN Keyboard
My laptop caps lock key was removed, where should i go for repairs?
  • 29 Answers
Take a look at www.replacementlaptopkeys.com, they sell individual laptop keys replacement for all brands of laptops, they will be able to get you what you need. Good luck.
Posted on Sep 10, 2010
How do I reset keyboard on acee laptop to use white characters on keys not blue
Press function key (fn) and num lock key together far as I can remember .
Dec 14, 2014 | Acer Computers & Internet
Compaq memory
Remove one at a time, and try to reboot, alternate one for the other. Remove the battery, leave battery out, and unplug each time during process. The Cap Lock? Does the HDD led blink? Do you get anything on the screen?
Apr 27, 2013 | Compaq Presario CQ60-220US PC Laptop
Dell Studio 1737 with Back lit keyboard but Cap Lock Doesn't Light
Dear Janice,
The light under the Caps key must have burned out. Take your laptop to a Dell service center and get it repaired.
Oct 19, 2012 | Dell Studio 1737 (Studio 1737-RubyR) PC...
How i can unlock shift
If you are printing all CAPS then it is the Caps Locks key. It is located just above the shift key on the left side of the keyboard. There should also be a light on the laptop indicating the Caps lock is on.
Hope this helps
Jun 11, 2012 | HP Computers & Internet
The scroll number lock key and the caps lock key are blinking and my lap top will not bbot up. I have a blank screen
This is usually indicative of an internal malfunction. You can try unplugging it from power, removing the battery and holding down the power button for 30 seconds with everything removed (to discharge any capacitors on the motherboard.) Then plug everything back in and try to fire it up. If it still doesn't work, there's a good chance the unit will need service. Local repair shops can usually be found on google maps or craigslist
Mar 01, 2011 | HP Computers & Internet
How to put off number keys on my laptop? my laptop has both numbers n letters on a few keys
most thinkpads use 'hold down shiftkey and press Numlk/Scrlk key' should also toggle a led off & on next to the caps lock led. looks similar to caps lock but the arrow has a 1 in it for number lock when the caps lock uses the letter 'A'
Dec 23, 2010 | Lenovo ThinkPad W500 Notebook
How can i repaire my kerboard of aser 5920
Remove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
These separators secured on the back of the keyboard.
Plastic pins are melted on the back of the keyboard and retain separators in place.Push all plastic pins though wholes on the keyboard.Start removing the separator.The plastic separator has been removed.
Now you'll have to remove all key caps.
Before you start removing key caps, make a picture or xerocopy of the keyboard so you know the order in which keys are attached to the keyboard.In order to remove the key cap carefully lift it up with your fingers.Remove the key cap so the hinge underneath stays connected to the keyboard.
Some big keys have a different design.
In addition to the hinge, some big keys (Back space or Space bar for example) might have an additional support bracket.Remove the key cap with the support bracket. As you see, the key hinge stays connected to the keyboard.Some laptop keyboards might have blank covers on the left and right sides from the up arrow key.Lift up and remove the blank cover.All keyboard key caps and plastic separators have been removed.Now you can start removing key hinges - key lifting mechanisms.Carefully separate the key hinge from the keyboard.
Each key hinge has two parts - external and internal pieces.
When you remove the hinge, try to keep these parts connected to each other the same way they are connected on the keyboard.If the external and internal pieces got separated, you can assemble them together.If you following this guide to repair the keyboard, I would recommend to keep all hinges in the right order.
The keyboard has two sheets laying one on the top of another.
Remove the sheet with silicone (or rubber) nipples.Remove the second sheet with traces.Both sheets have been separated from the keyboard base.The sheet with traces has two layers and all traces are running between these layers.In order to access and repair traces you'll have to separate to layers from each other.The keyboard has been disassemble.
As you see it's not easy to disassemble a laptop keyboard and even harder to put it back together.
Is it worth repairing? Probably not. These days you can find a new laptop keyboard very cheap.
Oct 17, 2010 | Acer Computers & Internet
Need to replace broken key on keybord. plastic appartus on key underside broke
Oct 17, 2010 | HP Pavilion ZD7140US Notebook
My cap lock won't lock, however I can get a
Gently removed the CAP LOCK KEY and inspect for dirt or a broken retaining clip. If dirty blow it out. If the clip is broken the key will not work I'm afraid to tell you
Jul 17, 2010 | Dell Inspiron E1705 Notebook
Caps lock key
Normally, Caps Lock is known as a toggle key.
Press once to enable caps lock, press the key again to disable caps lock.
May 16, 2008 | HP Pavilion dv1000 Notebook
Acer NSK8458AN Keyboard Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
