Question about Cingular Wireless Computers & Internet
I mistakenly moved the windows documents on the device to storage card and on the course i stoped it and eventually now i can't access any program on the device and the start menmu is blank and likewise i can't hard reset and also access the storage card
    Brigadier General:
  • 3,006 Answers
Your device needs a complete software reinstallation from scratch. There is no other way to fix it. If you don't have the correct software installation disks (not normally supplied to the user) then the device must go to a service centre.
Posted on Sep 10, 2010
Use of storage card
Gordon, Move the stuff on tablet to the SD card to free up space.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Move Android Apps to an SD Card
Galaxy Tab How do move photos videos and other files on my Samsung Galaxy...
internal storage full how to move to SD card
Aug 04, 2016 | Tablets & eReaders
Deleter files recovery
you may download this hard drive recovery software called asoftech data recovery that helped me before, download from link below
File Recovery Program
Sep 13, 2012 | Computers & Internet
Tmobile mytouch Q 4G Slide....running very slow not letting pull up dial pad battery running hot and running out fast freezing up internet not working alot needing to restart the phone all the time
  • Close unused programs by accessing the Task Manager on the device. According to MobileTopSoft.com, Windows Mobile devices use a feature called "Smart Minimize." This software simply minimizes a program when you think you might have closed it. Thus, the device becomes slow because too many programs are running. Closing out programs via the device Task Manager should be completed daily.
  • 2Clear the temporary files from the device. Storage on a Windows Mobile device is at a minimum, and it's important to keep the phone cleared of any unnecessary data, such as temporary Internet files. To complete this task go to Internet Explorer and access "Menu," "Tools" "Options" and finally "Memory"; delete the files here.
  • 3Avoid overloading the device with unwanted programs. Programs take up storage space on your device. By taking caution when downloading programs and removing unwanted programs, you will minimize the amount of storage taken up. This will reduce the slowness of the Windows Mobile device.
  • Sincerely. G-d bless you
    ERNESTO CUADRA
    mANAGUA, NICARAGUA
    Dec 15, 2011 | LG Cell Phones
    Hi my htc touch diamond restarts randomly few times a day. can anyone help
    try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
    update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
    also if that doesnt work try doing a soft and/or hard reset -
    Performing a soft reset
    Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
    To perform a soft reset
    1. Pull out the stylus, then remove the back cover.
    2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
    HTC Touch Diamond 2 hard reset
    Performing a hard reset
    If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
    Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
    Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
    To perform a Diamond 2 hard reset
    1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
    2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
    3. Release the VOLUME UP and VOLUME DOWN buttons.
    4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
    Dec 29, 2010 | HTC Touch Diamond Smartphone
    Hello! I have a problem. My HTC Diamon 2 in Russian I need to change it from Russian to english.is it possible? and can u help me please how to do it step by step, Thank U VERY MUCH
    If you perform a hard reset, it should allow you to choose the language the phone displays. Just be sure to back up all your info/programs you have on the phone because it will go back to factory default when you do this!!!
    If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings—the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
    To perform a hard reset
    1.
    This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel.
    3.
    Using Clear Storage
    If you can access the device settings, you can use Clear Storage to reset your device back to factory default settings.
    1. Tap Start > Settings, and then tap All Settings.
    2. On the System tab, tap Clear Storage.
    3. Enter "1234" and then tap Yes.
    Dec 17, 2009 | HTC Touch Diamond Smartphone
    Drive No Longer Appears as an Available/Accessible Drive
    goto disk management - right click and choose assign/change drive letter
    Mar 18, 2009 | Electronics - Others
    What does Windows Vista error 0x00000005 mean?
    Applications that are reading file allocation table (FAT) based storage devices at the time of a resume may receive the following error message from the file system: ERROR_ACCESS_DENIED (0x00000005) This occurs although the file has appropriate sharing and access permission.
    Examples of storage media that frequently use the FAT file system on Pocket PC 2002 are the PCMCIA PC Card ATA, the Compact Flash (CF) Storage Card, and the Secure Digital (SD) Memory Card.
    This behavior is observed when using Pocket PC 2002 Adaptation Kit Update 4 (AKU4) and later.
    RESOLUTION:
    Applications can handle this situation by detecting the specific error code while reading a storage card file, and then retrying for a short period until the device is ready. The following is an example C code fragment that demonstrates this concept: while ( !WriteFile( hFile, achBuffer, dwBytesRequested, &dwBytesReturned, 0 ) &&
    ( ERROR_ACCESS_DENIED == GetLastError() ) )
    // Access Denied: Maybe the file system is not ready yet.
    tries++;
    if ( tries > 4 )
    break;
    Sleep(500);
    // It has been a few seconds. The file cannot be accessed.
    You can use the same approach for other programming languages. For applications that access the storage card through middleware libraries that do not provide direct access to the file system, you may have to implement transactional or block verification methods to get reliable data transfer across a suspend resume.
    Mar 09, 2009 | Microsoft Windows Vista Home Premium with...
    Cant find SD card
    The 4 gig card is the problem. I bought a 4 gig for mine and had the same problem. My wife had a 1 gig and I tried it in my phone and it worked fine. So I traded with her. Made a file on the computer to offload all her stuff, and reload mine. It sucks you can't use a larger card, but it is what it is!!
    Jan 16, 2009 | Pantech Duo Smartphone
    Samsung i900 - insufficient memory when trying to take photo.
    The phone has 3 memory's
    My device about 90MB which is where everything gets stored by default and because it's the smaller memory it will easily get full.
    My storage about 8 GB (handset internal memory)
    Storage card about 8GB depending on your contract (Memory card)
    You will need to move items from the "My devices" memory to either the "My storage" or " Storage card"
    Start
    Programs
    File explorer
    My device
    My documents
    Tap and hold on a file
    Select cut
    Go to my storage or storage card which ever desired memory
    Tap and hold paste.
    Try change default storage for pictures and video.... So that they no longer saved under My devices memory.
    Open camera as you about to take a picture tap on the tool icon
    tap on the tool
    change default storage to my storage or storage card
    Also change default storage for files transferred via bluetooth...
    Start
    Settings
    Connections
    Bluetooth
    Tap on FTP tab
    tap on the bar with 3 dots
    select desired default storage
    Works like a charm!
    Oct 06, 2008 | Cell Phones
    Data Reconstruction
    Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
    Download from the following link ------
    http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
    Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
    For any other help contact me.
    Thanks
    Feb 22, 2008 | LG RH177 DVD Recorder/HDD Recorder
    Computers & Internet Logo
    19 people viewed this question
    Top Cingular Wireless Computers & Internet Experts
    jmcoll
    Jim Goldsmith
    Jim Goldsmith
    fordexpert
    Are you a Cingular Wireless Computer and Internet Expert? Answer questions, earn points and help others
