Question about Whirlpool Duet GHW9150P Front Load Washer
Something is stucked in it how do i remove it
  • 92 Answers
There must be a button near the dryer or where water comes out just press and hold it
Posted on Sep 10, 2010
Testimonial: "yes i found it"
Washer will not drain. Filter was removed and cleaned. Washer makes humming noise
Most likely there is something stuck in drain pump open the drain pump hose and check if something is stuck there.
Aug 22, 2014 | Washing Machines
How do you remove the housing? Something stuck in there.
I would try removing the foot plate and feed dogs first. that is usually where a knot of thread can disable the machine.
Aug 07, 2014 | Euro-Pro Sewing Machines
Frequently, while I am sewing, the needle hits something below the guide plate and gets stuck. I have to remove the guide plate and then the needle will release. What is the problem with my machine?
If the needle gets stuck with no thread, The needle is hitting something. Could be needle not up all the way or something needs adjusting. If it gets stuck with thread. It is probably an upper thread tension or threading issue.
Apr 05, 2014 | Juki DDL-8300
Remove the drum on a top loaded washing machine
odds on something being between the tub and basket is very small.  noise probably coming from brake/clutch or transmission just to name a few possibilities...
Jul 24, 2010 | Whirlpool Washing Machines
Something is stuck in my printer that is showing up on copies (I think it's piece of sticky paper from address label)
Your description is not very very descriptive, so I dont know if that stuck piece, prevents the ink from hitting you page. But, if you know how to remove your cartridge, I am sure you should be able to have a good view of the paper rollers [depending on your brand of printer] that drive the paper towards your output tray. If something is stuck, by rotating them, which is not a very easy task in some printers, you should be able to bring into view the piece that is stuck
Jun 18, 2009 | Dell 1600n All-In-One Laser Printer
I think something is stuck under the washer basin I don't know how to remove agitator
on the old type you turn the centre top to unscrew it. pull up the agitator and replace the same way
May 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Doesn't flush properly. I have removed from base but can't push
it sounds like you have something stuck in the toilet.What you need to do is try to snake then toilet.You can also remove the toilet and turn it upside down after you remove all the water in the bowl.after you turn it upside down you should be able to see if their is something stuck in the bowl.
Jan 31, 2009 | Kohler Bathroom Accessory Set with Classic...
Jammed washing machine filter
It is stuck because there may be something stuck in the filter, or it is the rubber seal that has expanded, try levering it out with a screwdriver or something like that, or if there is something you can grip with a pair of grips or pliers ,try pulling it out that way.
Plz rate solution.
Thanks
Dec 26, 2008 | Samsung Washing Machines
Sounds like something stuck in the washing machine when draining
Something has become stuck in the drain pump.
1. Remove the back cover. The drain pump is in the lower left corner.
2. Tilt machine forward for easier access.
3. Unplug the pump motor power plug.
4. Loosen the hose clamp from the tub.
5. Remove the drain hose connection from the pump.
6. Remove the three screws securing the pump to the tub.
7. Remove debris from pump.
8. Replace pump.
9. Merry Christmas...
Dec 25, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
