Question about Garden
Briggs lawnmower 5-hp engine locked up due to overheating of piston along full length of cylinder at valves. Engine ran well for about 10 hours service after recent overhaul, but did appear to be running full open and not controlled by govener. What caused the overheat & how can I correct the problem?
  • 1,040 Answers
Well, if it did lock up on you, then you will need another engine rebuild. The reason for this happening in the first place is because it was running wide open. The governor spring must have been hooked up wrong, causing the motor to run full blast.
Jim
Posted on Sep 10, 2010
  • Jim Parker
    Jim Parker Sep 16, 2010
    Did this help?
    Jim
  • paul_eaton Sep 19, 2010
    Thanks Jim!
What causes push rods to bend on left bank of a 20 HP V- Twin
Here's some generic answers, not relating to this engine specifically:
  • The timing could be off, so the piston is hitting the valve.
  • A loose pin in the piston could be allowing it to extend too far, shoving on the valve.
  • I guess the valves could need to be adjusted so there's a gap.
Jun 02, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Crankcase is full of fuel
Lacy:
The float and needle valve in your carburetor are not working as they should. The float should force the needle valve into the carburetor body to stop the flow of gas when the float bowl is full. When the float and needle valve do not work as they should, the gasoline keeps flowing into the float bowl and into the carburetor, and into the cylinder where it flows past the piston rings and into the crank case.
The carburetor needs to be removed and cleaned.
May 15, 2015 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 21 hp Briggs and Stratton model #331877, what are the valve settings?
Intake 003 - .005
Exhaust .005 - .007
Adjusted with the piston 1/4" past TDC of compression stroke for each cylinder.
Apr 10, 2015 | Craftsman Garden
How do you adjust valves
Check valve clearance while the engine
is cold.
1. Turn crankshaft counterclockwise until
piston is at top dead center on the
compression stroke. This prevents the
compression release from holding the
valves open.
2. Insert a narrow screwdriver or rod into the
spark plug hole as a gauge, then slowly
turn crankshaft counterclockwise until the
piston has moved down the bore by 1/4"
(6mm).
3. Using a feeler gauge, adjust
rocker nut to obtain the clearance.
4. Hold rocker nut and tighten the rocker ball
setscrew to the torque valve.
5. Check clearance again and re-adjust, if
necessary.
6. Repeat for other valve.
7. If twin cylinder repeat the above for the other cylinder.
NOTE: On some models, the nut and setscrew
are positioned above the push rod ends.
Mar 14, 2015 | Briggs & Stratton 31N707-3026-G5 500cc...
Briggs and Stratton 23 hp lawnmower engine exhaust valve keeps sticking
it is possible that the valve stem is bent or has a build up on the stem that is jamming in the guide. Pull the head and replace the valve.
Sep 27, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
How do set valve lash
Turn the motor until the piston is at TDC. Look through the spark plug hole. piston to top of the cylinder. Then set them like you would any OHC rocker arm. BE very careful with the exhaust valve adjustment. There is like a mini disc on top of the valve stem spring keeper. If you get it too loose on a vertical engine it can drop out and it will take you forever to find the little bugger!
Below is only a recommendation....
I don't know how many hours that are on this engine your working on but... I would recommend you hand lap the valves with grinding compound if you know it has high engine hours. It will make it easier to start and have more power. The exhaust valves on these engines get very noteable black gunk buildup in the seat to the point you can not see the "valve to seat" mating ring on the valve head. The heads are not hard to remove... (One at a time) just time consuming. It can be a chore getting the valve push rods aligned with the engine horizontal. Most of the time and I know good Mechs don't like to hear this.. you can reuse the cyl head gasket on this model due to the design. Once in a while they break not very often.
The valve springs have keyhole locks on the keeper.
Thanks for using FixYa,
Kelly
Apr 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
0 compression onright cylinder
If you have 0 compression then either a valve is stuck open or you have a broken compression ring or hole in the piston. You will have to take the engine apart to find the problem.
Apr 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 22 hp V Twin ELS Briggs. After setting up a while during winter I found the intake push rods were bent (5-09). I removed both heads and repaired. Ran like a new one all summer. About a month ago I...
Push rods are not the same length Refer closely to the manual.
Push rod problems can also be due to valve adjustment. When adjusting the valves check to see if the rocker nut has a torx set screw in the center. Read Manual carefully.
Personal notes:
This is a recurring problem for the engine.
Have you been keeping up with regular oil changes? Have seen stuck valves more in B&S engine if owner could not remember the last oil change.
Use the good stuff and change every 30 hours.
Rotate engine by hand after long terms of setting up. imagine setting peacefully after a long winter and some pushes your starter switch and you go from 0 to 3600 RPM, something going to give.
Lastly do a exhaust manifold Temp test after it warms up and running at full speed. is one side hotter than the other. It is also not uncommon for the High speed jet to be clogged causing one to starve and run lean, by product over heat. Try using a fuel inhibitor with some carb cleaner. Also stay away from ethanol fuel if you can, there is a difference.
Hope one of the tips help to solve your problem.
r/
David
Dec 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Briggs and Stratton 16 hp v twin..replaced con rod and piston
Needle and seat not functioning ... float stuck or trash in needle and seat of carb.
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
