Question about Cycling
Not much problem but after years of use , performance seems to be softer. What air pressure do i use?
    President:
  • 1,514 Answers
You don't say what kind of bike it is. If it's a push bike the maximum air pressure should be written on the side of the tyres. For road racing bikes it's normally up to 100 psi.
Posted on Sep 10, 2010
Tyre pressure for 215/65 r16 tyres on a 2014 lwb ford transit custom
Hi I'm Peter, all tires actually have the max air pressure listed on the side of the tire and it varies as to what the tire is used for. Car makers list the tire pressure they prefer you to use in the vehicle manual. They usually have a lower setting than the max pressure posted on the tire. This is so the vehicle will have a softer ride. As a mechanic I always use the max pressure for better gas mileage.
Jan 01, 2015 | Ford Cars & Trucks
What is the correct tire pressure for a 1998 buick park avenu
32lbs to 35lbs. make sure all tires have the same pressure. then you will have to drive to reset the light.
Aug 24, 2014 | Cars & Trucks
Engine boggs out when stopming on accelerator for passing gear.
Please provide year, make, model, engine size, any repairs, and tests performed. If your just looking for quick ideas I will suggest looking for vacuum leaks, is the engine light on (what are the codes, if any)? Inspect the MAP and MAF sensor, fuel line pressure, timing, clogged fuel and/or air filter, Slow response from TAC unit or Idle air control valve (depending on the year), did the vehicle sit for an extended period of time (old or bad gas could affect performance), and exhaust back pressure. I hope that helps.
Feb 26, 2014 | GMC Cars & Trucks
Rear suspension rides really hard 24 lb air in shocks
Then lessen the amount of air. You can run 2 lbs or 50 lbs. in that year. You just have to find the happy spot for you. Some guys like it softer than others.
Aug 29, 2013 | 2008 Harley Davidson FLHTC Electra Glide...
I added air shocks to my 1995 lincoln town car because the air suspension bags died. what pressure should they take and do they lose air so you have to add air?
The Stock Air Bags self Leveled, your new System should have come with PAperwork or is there a Air Nozzle that you have to fill? The Bags should come with a Pressure Window for a Firmer Ride or Softer Ride.
EACH MANUFACTURER has their Own Particular limits and ranges...
Apr 05, 2013 | 1997 Cadillac DeVille
Poor engine performance,especially at high speeds I can feel there is a slight ****,sometimes a hard **** and sometimes softer but more frequently.I have replaced the fuel pump,fuel filter,spark plugs,air...
Sorry on this one as to be truthful i would need a drive and feel to have even the slightest incliniation as to what could be wrong,This could be a turbo pressure fault or even a jammed waste gate on the turbo ,maybe even a fault with the ECU who knows ?? a better man than me gunga din thats for sure .Trying to answer a question like this is difficult as you can imagine from a distance so ask a local man to have a look and post comment and then i can agree or disagree and think about something else associated with this fault but untill i get more input iam afraid i can only guess and this could cost a lot of money and not cure the fault
Feb 04, 2012 | 2000 Volvo S40
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
What is the correct front and rear tire pressures for a 1999 Z24 Cavalier convertible. Our driver side door was replaced and the sticker is missing.
I think there is another other sticker in the back cover of the spire tire cover in the trunk, but you can go by the the tire pressure label on the tire it self and run the rear tire pressure 4 pounds less then the front. The front always have more since that is where the engine is and the rear has no weight so a softer tire will keep the rear end from hopping around bumpy corners. I believe the proper tire pressure on the Z24 if it's the correct tire is 42 lbs cold front and 38 lbs cold rear if you like the performance feel and if you like the softer feel, then drop it by 6 lbs both front and rear. Good luck and hope this helps.
Jul 12, 2009 | 1999 Chevrolet Cavalier
Benjamin Air Rifle Model 342 not building pump pressure
Springs tend to loose their performance after a few years is air rifles. Check also the seal/o rings on the piston rod and the blow hole. I found waxing it with Vaseline makes it last longer and seals more.
Mar 27, 2009 | Dmm Benjamin Air Rifle
Bendix Washer/Dryer - softener dispenser not working
the softer dispenser is blocked, remove drawer wash it out with hot water ,clean out small hole in softer compartment close IRE bye
Aug 16, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Cycling Logo
44 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
