Question about Xerox C2424 Copier
Xerox c2424 has error message "Waste Tray Missing". Have emptied waste tray which was overflowing and placed it back in machine but above error message means it will not work.
  • Xerox Contributor
  • 185 Answers
The Waste Tray Optical Sensor 119-6487-80 is probably bad, which contributed to the overflowing ink. Look at the diagram #6
Whit
Posted on Oct 22, 2010
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
Empty Tray
@Derekns74 How do you remove the switch? My C3000 also reads "EMPTY TRAY" constantly, even if the tray is empty and clean. It does not display the "EMPTY GROUNDS" error only "EMPTY TRAY"
If I remove the tray it display "TRAY MISSING" but whenever I insert the tray again, it reads "EMPTY TRAY"
On one occasion when our power went out, it fixed the machine, so that it stopped reading "EMPTY TRAY," but after a day or two it stopped working and displayed the same EMPTY TRAY error message again.
Aug 04, 2013 | Jura Capresso C3000 Espresso & Coffee...
Xerox phaser 8560 printer is saying waste tray missing but it is not
Are you sure you are looking at the waste tray, and not the paper tray? Here is a link to the user manual for the printer. Information about the waste tray is on page 194. This should give you an idea of were it is located.
http://download.support.xerox.com/pub/docs/8510MFP/userdocs/any-os/en/user_guide_en.pdf
hope this helps
Feb 22, 2012 | Xerox Phaser 8560/YN Printer
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
Waste tray message will not leave display panel even though tray is empty
You will most likely have to remove ( looking at the machine from the front) left cover and clean out some spilled ink from the waste tray sensor.
You have to remove one screw from the back top of the cover, then the top front of the cover. Lift up and out on the cover to release the tabs and pop the cover off. Then have someone slide the waste tray in and out so you can locate where that tray seats into the sensor.
Most of the time, some ink spills into that area in the back of the waste tray, and blocks it from sliding all the way in.
Jan 05, 2010 | Xerox Phaser 8500/DN Printer
Phaser 8550 fault 26,962.64, anyone know how to fix this fault?
My 8560dn showed that message - it was not a heater or anything weird. I removed the waste tray; emptied it and re inserted - and rebooted the printer. it spent quite a while cleaning - but it prints fine now.
the waste tray was 'stuck'. To remove, I first removed the maint kit and then with a flashlight shined inside, saw there was a lever on the right side which, when I moved it, released the waste tray. Voila - road to success (and no service call). Have a spare set of ink on hand as it uses a bunch going through the cleaning process.
This turned a useless paperweight back into a productive member of my office society.
Nov 24, 2009 | Xerox Phaser 8550DX Laser Printer
Control panel show waste tray missing but the waste tray is in. This is a Xerox phaser 8550 printer
I do remember a switch way inside that can come loose, but check for your error at
www.partsdrop.com a very helpful xerox site.
Sep 17, 2009 | Office Equipment & Supplies
8550DP
That usually is a sensor failing. You can try to locate it (in the area where the tray goes) and see if it is loose.
Good luck.
Dec 13, 2008 | Xerox Phaser 8500/DN Printer
Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Error Msg: Maintenance drawer A is missing - Phaser 8200
There is supposed to be an orange chip on the back of that tray.
If that is not present or seating properly that will cause that problem.
Pull out the green tray and see if the chip is snapped on the back ot the maintenance tray.
Oct 17, 2007 | Xerox Phaser 8200 Laser Printer
Xerox C2424 Copier Logo
267 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
